June 20, 2014, 15:45 |
Viscosity when liquid turns to solid ??
LOTFI OULD ROUIS
Rep Power: 12 |
Hi guys,
I've got some troubles when using the "solidification and melting mode" in Fluent. I'm simulating an ice melting and solidification and I was wondering if it is possible to give an infinite value to the viscosity once it becomes solid because the "solidification and melting" mode keeps the same viscosity value wheter it is an ice or water..... which is not true. any suggestion would be appreciated thanks a lot Loffy |
amg, floating point exception, ice, temperature, viscosity multiphase |
Liquid Variables in Solid Domain | callahance | CFX | 1 | January 27, 2014 17:59 |
Liquid and Solid properties in Condensation and solidification | sourav | Fluent UDF and Scheme Programming | 1 | April 2, 2013 09:13 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 09:56 |
Shacking CAN VOF HEAT LIQUID SOLID | Optixxx | FLUENT | 0 | July 30, 2005 12:42 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
