calculation of heat transfer coefficient for bank of cylinders |
May 30, 2014, 05:10 |
sid
Rep Power: 12 |
hi guys
I am new at using ansys and the problem i have in hand is to find the cooling time for a array of cylinderical wires from 80degree celius to 50 degree celius the conditions are laminar cross flow over the cylinder forced convection I somehow managed to get the empirical fomulation of convective heat coefficient for a single wire using empirical corelations but what should i do find the h for a in line configuration of cylinderical wires I read that it can be done using CFX ansys but i am unable to do it I know that the h will vary as the air flows over the cylinders in one row Please help an early response will be appreciated Please if anyone has any idea kindly do share I am in deep trouble and not getting any help |
May 30, 2014, 07:55 |
transient analysis
Marcin
Rep Power: 13 |
Hey,
You can use CFX and transient analysis with initialization tmeperature on solid domain. You dont need to use heat transfer coefficient, program will obtain automatically |
May 30, 2014, 11:21 |
sid
Rep Power: 12 |
thanks but can u in brief tell me how to do it
May 31, 2014, 07:43 |
Marcin
Rep Power: 13 |
On the tree you click on analysis type and choose transient, when you make this
you must obtain your simulation time . in the first phase you can choose 10 s ( when your model is not complicated - no a lot of finite elements). The next step is to define bc and interface model. You must chase surfaces contact on the interface model and make heat transport on there. On the temperature transfer coefficent make none. CFX obtai this automatically. On post You can measure this temperature transport coefficent. Sorry for my english Best regards |
June 2, 2014, 02:15 |
sid
Rep Power: 12 |
whats is interface model is it the geometry of the object ???
which part needs to be done in cfx and which part in transient thermal??? |
Heat transfer coefficient - what is waht | Stan | FLUENT | 28 | December 29, 2021 17:29 |
calculate heat transfer coefficient in repeated geometry | mullenc525 | CFX | 4 | January 24, 2017 15:30 |
Porous domain:Interfacial area density and heat transfer coefficient | l.te | CFX | 2 | May 18, 2014 00:45 |
MRF and Heat transfer calculation | Susan YU | FLUENT | 0 | June 2, 2010 09:46 |
CFX doesn't continue calculation... | mactech001 | CFX | 6 | November 15, 2009 22:25 |
