May 30, 2014, 04:02 |
Rotating flow
SHEIKH NASIRUDDIN
Rep Power: 13 |
I'm working with Ansys fluent 14.5(RANS-LES). My domain is a rotating cylinder and fluid flowing thru it. While setting cell zone shall I set frame motion with amount of angular rotation? Is wall motion is to be set? In setting inlet boundary shall I set axial, radial and tangential velocities values? There are two cases :1) Flow is entering the inlet of the domain at absolute velocity, 2)A rotating flow is entering the inlet of the domain. Is there anybody to help in these setting?
nasir.iitd |
May 31, 2014, 02:56 |
#2 | |
Amin
Rep Power: 15 |
for frame motion you must define the rotation for the domains in cell zone! for rotary domains active frame motion and for stationary domain just define rotation axis! then in the boundary condition for rotary wall select "stationary wall" and for non-rotary wall select "moving wall" & "absolute" then enter "0" for speed! |
May 31, 2014, 06:43 |
rotating flow
#3 | |
SHEIKH NASIRUDDIN
Rep Power: 13 |
Thanks for the kind help. My complete domain is rotating. I've set the following BC. In cell zone- Frame motion>amount of rotation in rad/s>specified rotational axis. In velocity Inlet-Component>relative to cell zone>cylindrical coordinate>Axial velocity in m/s>Radial and tangential vel. set 0 m/s >angular vel.set 0 rad/s as frame motion is set. In Outlet- Pressure outlet>gauge Pr. set 0 >normal to boundary>Radially equilibirium pr. distribution>back flow set to 0. in wall>stationary wall (as the frame is rotating by default the is also rotating). Is my settings o.k.? But KE decay profile, tangential vel.and radial vel. profiles are not as expected. Need your further help please. |
June 1, 2014, 02:14 |
#4 | |
Amin
Rep Power: 15 |
June 1, 2014, 07:06 |
rotating flow
SHEIKH NASIRUDDIN
Rep Power: 13 |
Dear Amin,
I'm attaching the snapshots of Velocity inlet and Pr. Outlet Bc for your understanding. Nasiruddin. |
June 2, 2014, 13:22 |
Andrew Kokemoor
Rep Power: 14 |
As you have it set up, the flow enters with rotation. (It has no tangential velocity relative to the rotating cell zone.) If you mean for it to enter without rotation, you can change the Reference Fram field to Absolute in the velocity inlet specification.
June 2, 2014, 13:41 |
SHEIKH NASIRUDDIN
Rep Power: 13 |
Thanks Kokemoor,
The cell zone is fluid and rotating.There could be two cases: 1)Fluid entering the inlet with rotation /swirl-It is required to set relative to cell zone in the reference frame field of velocity inlet specification and calculated value of tangential velocity is also to be set. 2)Fluid entering the inlet without rotation-In this case Reference frame field is to be changed to absolute. Am I correct? Are the rest of BC settings O.K.? Is pr. at the outlet to be set?In my case y+ distance is 6.5 i.e. first grid point from wall lying in buffer layer and Re No. is above 50,000. Can LES run give reliable result? |
rans_les |
Laminar flow simulation in rotating domain | rahulv | CFX | 7 | July 9, 2014 07:19 |
Flow past rotating cylinder | sam.ho | OpenFOAM Running, Solving & CFD | 4 | October 10, 2013 08:49 |
impinging jet flow on rotating disc | trentar | Main CFD Forum | 0 | October 5, 2013 05:30 |
Rotating flow through a construction | EA1990 | Main CFD Forum | 0 | July 13, 2013 11:49 |
Re: flow through a rotating serpentine passage | Paulas | CFX | 0 | January 23, 2009 23:01 |
