velocity magnitude and direction!!
Like Tree2Likes
  • 1 Post By CFD-fellow
  • 1 Post By LuckyTran
Old   April 30, 2014, 17:12
Default velocity magnitude and direction!!
Astio Lamar
asal is on a distinguished road
Hello everybody.
I have a problem to set the velocity inlet boundary condition in form of "velocity magnitude and direction".
I want to introduce 2m3/s to my domain. So by having the inlet area I did the following:
2/inlet area = inlet velocity.
When this value assigned in the form and velocity, normal to boundary, I got the correct volume flow rate at the inlet.
But since the inlet velocity is not normal to boundary, I set the direction:
X-component of Flow Direction: 0.5627
Y-component of Flow Direction: 0.8267
then I got 1.65 m3/s in the inlet!!
Does anyone know what is the problem? why it is so? and what is the solution?
thanks.
asal is offline   Reply With Quote
Old   April 30, 2014, 18:44
Behrooz Jamshidi
CFD-fellow is on a distinguished road
Hi
According to your data i think your inlet face normal vector is in y direction.
When you say for normal velocity it is correct but for non normal velocity its not, this shows that Q/inlet area=inlet velocity is not a scalar equation its a vectorial equation.
For having 2m3/hr at face, you should set a volume flow rate so that its y (normal vector direction of your face) component equals 2m3/hr.
Regards
asal likes this.
CFD-fellow is offline   Reply With Quote
Old   May 1, 2014, 06:14
Lucky
As the person before me suggested, the x,y,z-component of flow direction are the scalar components of the flow vector. Each of those components carry the units (default is m/s).
Depending on which plane your inlet lies in, you need to specify the right x or y component velocity to get the desired volumetric flowrate. And then specify the other component to get the desired direction.
asal likes this.
Old   May 2, 2014, 04:12
Astio Lamar
Hello and thanks for your reply.
@ LuckyTran: Would you please advice how can I set the correct x and z component of velocity to have 2m3/s flow rate on the inlet? degree = 30
Old   June 20, 2017, 18:59
Tarantino
Tarantino is on a distinguished road
Hello all,
I have the same problem, Asal. did you fix the problem?
Consider the following example:
Inlet is normal to -Y with total area of 0.1 m2.
1 m3/s should be imposed to the inlet with 65-degree deviation from the inlet normal.
In this case:
velocity = 1 [m3/s]/0.1 [m2]= 10 [m/s]
therfore:
y-component = 10*cos(65)
z-component = 10*sin(65)
However, this will not give the desired volume flow rate (1 m3/s)
Can anyone explain this?
thanks.
Tarantino is offline   Reply With Quote
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 01:04
Paraview - 2d vector glyphs colored by vector direction & magnitude newOFuser OpenFOAM 2 March 11, 2017 14:51
Air diffuser velocity magnitude and direction kenzosenzo FLUENT 17 March 31, 2014 08:03
Variable Velocity Inlet magnitude and direction Brendan FLUENT 0 March 24, 2014 07:24
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
