Rep Power: 13 ![]() |
Dear all,
I am modelling a simple waste heat boiler and I'm experiencing an unsuspected problem with the simulation. The model is quite simple, as hot flue gas is entering from one end and exiting from the other. Inputs are as velocity inlet and pressure outlet. Radiation: P1 Turbulence: rke, double precision Solver: Simple Momentum, turbulence and energy: 2nd order upwind As I started the steady state calculation, I noticed that the continuity equation is not stabilizing and at the end it affected all the other residuals as well and the results were not as expected/not as my experience tells me. The continuity did not oscillate as it sometimes does, it was just "chaotic". I refined the mesh and still the problem persisted. I coarsened the mesh, no effect. I switched to transient, but the continuity equation did not stabilize. I tried to solve the problem as first order, I tried to switch the solver, and tried to calculate only the flow field. No success. In the end I fooled around with Fluent and forgot to turn on gravity and BOOM - success! The calcutation converged as expected and the results were correct. The question is: can anybody explain me why gravitation messed the calculation. As it is a simple gas flow calculation (desity at the inlet = 0.35kg/m3) gravitation should not practically affect the calculation at all. I want to point out that I calculate similar cases in a daily basis and this was the first one which showed the above mentioned problem. Regards, O |
Behrooz Jamshidi
Hi
1-is your flow regime turbulent? 2-If you have correctly set the gravity acceleration, now just make gravity acceleration negative(if it is 9.8 put -9.8 and vise versa ) with the same direction as before. It seems somehow foolish, but test it and let me know the result. Best regards |
Hi cfd-seeker,
Yes, the flow regime is turbulent. I tried to reverse the gravity direction, but still the continuity equation diverged. Regards, O |
Behrooz Jamshidi
Hi
What about relaxation factors? Try solving the solution by 0.7 relaxation factor for pressure and 0.3 for momentum. |
I tried to tweak the relaxation factors up and down, but in vain. |
Ramin
Rep Power: 10 ![]() |
Hi.
I had this problem and it was solved in this way: you should "reorder" your mesh until achieving this notice in the command bar : >> Reordering domain using Reverse Cuthill-McKee method: zones, cells, faces, done. Bandwidth reduction = 372525/670 = 556.01 Done. >> Reordering domain using Reverse Cuthill-McKee method: zones, cells, faces, done. Bandwidth reduction = 670/670 = 1.00 Done. after that you can initialize and run *reorder : in Ansys Fluent 17---> menu bar--->setting up domain--->reorder--->domain Good Luck Ramin |
#7 | |
Kushal Puri
Rep Power: 12 ![]() |
Trot
Rep Power: 9 ![]() |
Is this "reorder" option available in Ansys 15? Thanks in advance
continuity, gravitation |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 17:02 |
Review: Reversed flow | CRT | FLUENT | 1 | May 7, 2018 05:36 |
Divergence after change in mass flow rate in two phase flow | meetsunilkale | FLUENT | 1 | March 25, 2013 03:03 |
Mass flow rate boundary condition for continuity equation for oscillating flow | p07ip705 | Main CFD Forum | 0 | February 28, 2013 01:33 |
What is the difference between liquid reactive flow and gas reactive flow? | James | Main CFD Forum | 6 | May 15, 2009 12:14 |
