Heat Flux at Interface
Like Tree2Likes
  • 1 Post By LaurenB
  • 1 Post By Bionico
Old   March 26, 2014, 16:12
Default Heat Flux at Interface
Lauren
LaurenB is on a distinguished road
I have a geometry where a finned structure is attached to a volume. The surface of the volume that is attached to the fins is generating heat. A fluid then cools the fins. An interface is defined between the volume and the fins and also between the volume and the fluid. I need that surface of the volume to generate heat.
I am curious about how to add a heat flux to a surface that is defined as an interface?
Thanks.
Svetlana likes this.
LaurenB is offline   Reply With Quote
Old   March 27, 2014, 03:24
Bionico's Avatar
Flavio
Bionico is on a distinguished road
Hi lauren,
can you post a picture of your system? I don't understand how you have set-up the simulation
Regards
Bionico
Bionico is offline   Reply With Quote
heat flux, interface
Applying heat flux at mesh/wall interface for a solid-fluid heat transfer? nit4tin FLUENT 6 August 19, 2018 15:50
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
CFX13 Post Periodic interface EtaEta CFX 7 December 8, 2011 18:15
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
heat flux on fluid-solid interface does not match Dai CFX 4 October 30, 2006 09:38
