Parallelize UDF? Which kind of UDF?
Like Tree5Likes
  • 1 Post By Lilly
  • 1 Post By ghost82
  • 3 Post By diamondx
Old   March 21, 2014, 12:16
Default Parallelize UDF? Which kind of UDF?
Lilly is on a distinguished road
Dear all,
I am a bit confused about which kind of UDF I have to parallelize, when I use several nodes for calculation.
I was told that I don't have to parallelize a viscosity UDF (DEFINE-PROPERTY), since the calculation only uses information from the same cell.
Now, I also wrote a UDF for a velocity an mass fraction profile (DEFINE_PROFILE) at the inlet of my geometry and a UDF to define my mass diffusion coefficent depending on the strain rate (DEFINE_DIFFUSIVITY).
I didn't parallelize them, but they seem to work.
I now read that DEFINE_PROFILE udfs should be parallelized as well.
Is this true? And what about the diffusivity? And would I have gotten an error message, if the udf didn't have worked in parallel mode, or shouldn't I trust the results now?
Thank you for any help!
Lilly
ghost82 likes this.
Lilly is offline   Reply With Quote
Old   March 21, 2014, 12:30
ghost82's Avatar
Rick
ghost82 will become famous soon enough
I'm also curious about this question, as I also worked with udfs and parallel cores without changing the code, and also to me it seems all was ok.
All I can say is that the need of parallelizing an udf depends also on the way the mesh is partitioned among the different nodes; for example, if the inlet belongs only to a single node and you apply the udf, I think it doesn't need to be parallelized; on the contrary it should be parallelized if the inlet is divided among different nodes (..but I'm not 100% sure).
Awaiting for other replies.
Daniele
Lilly likes this.
ghost82 is offline   Reply With Quote
Old   March 21, 2014, 15:33
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
Hope this can help https://dl.dropboxusercontent.com/u/...n-parallel.pdf
macfly, ghost82 and Lilly like this.
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   March 24, 2014, 03:28
Thank you Daniele and thank you diamondx for your help!
Your replies helped me a lot and the link is really helpful!
So maybe you can also help me with another question (since I am really bad with C).
This is my udf:
#include "udf.h"
#include "math.h"
#define MU_INF 0.035
#define N_INF 1
#define DELTA_MU 0.25
#define DELTA_N 0.45
#define A 50
#define B 3
#define C 50
#define D 4
#define Dconst 1.5e-10
real mu;
real lambda;
real n;
real strain;
real d;
DEFINE_PROPERTY(cell_viscosity, c, t)
strain = C_STRAIN_RATE_MAG(c, t);
lambda = MU_INF+DELTA_MU*exp(-(1.+fabs(strain)/A)*exp(-B/fabs(strain)));
n = N_INF-DELTA_N*exp(-(1.+fabs(strain)/C)*exp(-D/fabs(strain)));
mu = 0.1*lambda*pow(fabs(strain),(n-1.));
return mu;
DEFINE_DIFFUSIVITY(diffusivity, c, t, i)
d = 0.53*Dconst+5.292e-9*strain;
return d;
  • I just realized I didn't but a point behind the defined values of N_INF A B C D (so if I got it right it's an integer instead of a floating point number). I already used this udf in several simulations and I didn't realize something strange. Do you know whether Fluent does have problems with this or whether the solution of the udf would be different, if I would have defined A B C D and N_INF as integer?
  • Concerning my original question: I hope I also got it right, that I don't have to parallelize the viscosity and diffusivity udf, since they are only working at each single cell and don't need to correspond? I guess it's the same for the Macro C_STRAIN_RATE_MAG(c, t) I used there, isn't it?
Lilly
Old   March 24, 2014, 04:39
ghost82's Avatar
Rick
Hi, your undefined "integer" values will be automatically converted because you defined the other variables as real, and in C language you cannot perform operations between integer and real values.
Probably you would have error if you define that values as integer.
For the second point, reading diamondx's document I understand that you have not to parallelize the udf, since, as you're writing, they are only working at each single cell.
Daniele
Old   March 25, 2014, 03:05
Thanks a million for this information and all your help, Daniele!
I am relieved to hear that! I hope I'll get better with C language and udfs soon...
I wish you all the best!
Lilly
UDF using c_face_loop(c,t,i) frederic FLUENT 3 January 17, 2017 00:17
Source Term UDF VS Porous Media Model pchoopanya Fluent UDF and Scheme Programming 1 August 28, 2013 07:12
Simulation with UDF for species mass fraction and velocity profile virgy Fluent UDF and Scheme Programming 8 February 7, 2012 05:30
UDF programming fullmonty FLUENT 5 June 30, 2011 03:40
Kind attn:problem in DEFINE_SOURCE in my UDF Phanindra FLUENT 1 February 23, 2007 10:03
