Species Mass fraction in Fluent
Like Tree2Likes
  • 2 Post By a_cucen
Old   February 26, 2014, 05:14
Default Species Mass fraction in Fluent
Prashant Thaker
prashantthaker208 is on a distinguished road
hello users,
need some help regarding specifying mass fraction of species in fluent
I have two inlets.. one from which only air enters...
and the other from which CO enters (g/s)...
For the air inlet I do not specify any mass fraction... (all species fraction 0)
for the CO inlet I specify CO mass fraction as 1.
Is this approach correct?
In the Fluent solver i have opted for species transport of air-co mixture template.
No reactions.
Kindly help,
Prashant
prashantthaker208 is offline   Reply With Quote
Old   June 10, 2014, 06:14
Manab
Manab is on a distinguished road
Dear All,
I have a similar question. I am trying to use CFD fluent for coal combustion where coal is carried by either CO2 or N2. I could use CO2 as a carrier gas from the species mass fractions. However, I can't find N2 in the species list.
It will be highly appreciated if anyone can suggest that how to add N2 in the species list.
Cheers,
Manab
Manab is offline   Reply With Quote
Old   June 11, 2014, 05:20
Ahmet
a_cucen is on a distinguished road
Originally Posted by Manab View Post
Dear All,
Cheers,
Manab
if you go to Mixture Species/ Selected species , N2 will be at the end of your selected species list. It means that while you are setting your mass fractions, N2 will be selected automatically. For example;
If you chose mass fraction of O2 to 0.23, N2 will be 0.77 automatically or if you chose 0.5, N2 will be 0.5.
Manab and khaledhmz like this.
a_cucen is offline   Reply With Quote
Old   June 11, 2014, 05:22
Ahmet
Originally Posted by prashantthaker208 View Post
hello users,
No reactions.
Kindly help,
Prashant
Could you explain more? or show a picture of your geometry?
Old   July 4, 2014, 00:41
Prashant Thaker
dear a_cucen,
I managed to solve my problem. I wanted to model the CO dispersion due to on-road traffic emission.
I modelled road as a mass flow inlet emitting CO (kg/s). I used to specify CO mass fraction as 1 for this inlet.
The other inlet varied depending on the direction of the ambient wind. NO CO mass fraction was specified.
Using this approach I got very high CO concentration (about 600-700ppm).
However, when switched to a volumetric source (defining a small zone above the road where CO is emitted), I got acceptable CO concentrations (1-4 ppm) which compared well with actual measured concentrations.
If anyone can explain why I did not get results by the first approach, I'd be grateful.
Regards,
Prashant
Old   September 30, 2020, 01:30
Mahesh
mahesh1819 is on a distinguished road
HI,
Can any one please mention what is the conversion factor used for getting the results in ppm. we are considering 1 ppm = 10^4 of mass fraction (which we are getting in Ansys).
Please tell this is correct or not and will it be changing depending on gas.
Thanks in advance,
Mahesh
mahesh1819 is offline   Reply With Quote
How to get the gradient of species mass fraction? legendyxg Fluent UDF and Scheme Programming 11 August 5, 2020 01:57
UDF for specifying species mass fraction gradient at boundary Zaphod'sSecondHead Fluent UDF and Scheme Programming 1 March 14, 2020 07:12
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
Difference between Volume Fraction and Mass Fraction in CEL foo7 CFX 0 September 21, 2011 09:45
Species mass fraction saeidm84 Fluent UDF and Scheme Programming 1 December 10, 2010 20:14
