How to specify source term with UDF by TUI
Like Tree1Likes
  • 1 Post By robboflea
Old   February 25, 2014, 18:33
Default How to specify source term with UDF by TUI
Michigan
lxlxlxt is an unknown quantity at this point
Hi all,
I'm having some trouble specifying the following the term in TUI:
Cell zone conditions-->airzone(zone name)-->polymer(phase name)-->source term -->energy source term-->User-defined source term.
I've checked using the following code:
/define/boundary-conditions> fluid
(polymerzone airzone)
zone id/name [polymerzone] airzone
(mixture polymer air)
domain id/name [mixture] polymer
Specify source terms? [no] yes
Number of Mass sources (0 10) [0] 0
Number of X Momentum sources (0 10) [0] 0
Number of Y Momentum sources (0 10) [0] 0
Number of Energy sources (0 10) [0] 1
Use Constant Source 1? [no] no
Specify fixed values? [no] no
Use Profile for Reference Frame X-Origin of Rotation-Axis? [no] no
Reference Frame X-Origin of Rotation-Axis (m) [0] 0
Use Profile for Reference Frame Y-Origin of Rotation-Axis? [no] no
Reference Frame Y-Origin of Rotation-Axis (m) [0] 0
Deactivated Thread [no] no
Porous zone? [no] no
There is not an option to choose user-defined function.
Can anyone help?
lxlxlxt is offline   Reply With Quote
Old   February 25, 2014, 22:04
Default Never mind. I got it
Michigan
Sorry for the trouble. I got it.
Old   August 21, 2017, 11:04
robboflea is on a distinguished road
For other people who may be having the same problem the answer is in:
/define/boundary-condition/fluid
(this will allow you to activate source terms for all equations and hook them to the appropriate UDF functions eventually)
Hope it helps
lxlxlxt likes this.
robboflea is offline   Reply With Quote
source term, tui
UDF for energy source term engloly Fluent UDF and Scheme Programming 11 June 25, 2017 07:05
UDF Source Term Christian FLUENT 4 August 1, 2009 06:53
The source term of UDF summer FLUENT 0 August 24, 2006 18:44
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 14, 2000 00:03
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 04:43
