Fluent 6.3: how to plott Local Nusselt number using Fluent ? |
February 21, 2014, 16:08 |
amine
Rep Power: 14 |
Hello everyone,
I 'd like to ask you the way to plott local nusselt number using Fluent 6.3 Ansys Thank You so much in advance |
February 21, 2014, 16:39 |
hi
farzadpourfattah
Rep Power: 13 |
hello.
plot>wall flux>nusselt number. first set effective length in reference value because Fluent use this length nu number calculation.(hL/k) |
February 21, 2014, 17:12 |
#3 | |
amine
Rep Power: 14 |
well i have here: plot>wall fluxes>surface Nusselt Number i set effective length as you said (heated wall) and plot but didnt get it, more informations please thank You |
February 21, 2014, 17:16 |
farzadpourfattah
Rep Power: 13 |
what is your mean: "i dont get it?"
February 21, 2014, 17:20 |
amine
Rep Power: 14 |
February 21, 2014, 17:25 |
farzadpourfattah
Rep Power: 13 |
if trend of Nu number is valid with experiment data but this value was wrong i had experience this problem.the length in reference value is cause of your problem.check this value and be sure form this value is calculate correctly.
February 21, 2014, 17:37 |
amine
Rep Power: 14 |
okkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkk
February 25, 2014, 09:03 |
Same nusselt number problem
Juhti
Rep Power: 12 |
Hi
I have had this very same problem this week with this simple exercise: 2D flow inside a cylidric pipe, L=10 (SI units for all); internal_radius=0.15; external radius=0.20 (aluminium pipe) with constant heat flux in the wall (2000), a symmetry BC, a velocity inlet and pressure outlet. I want to compare the Nusselt number obtained with Colburn's correlation. The doubt is, which reference numbers should I use? when using Area 3, Depth= 10 and length = 0.30 (hidraulic diameter for Nu=h*L/D) i just got the double, but 0.15, the radius, it feels like cheating for me. Thank you in advance |
February 25, 2014, 11:39 |
#9 |
Rick
Rep Power: 27 |
by definition, for internal flows in pipes the characteristic length is the hydraulic diameter. Nusselt is h*L/k not h*L/D. Make sure to calculate correctly the heat transfer coefficient (check the reference temperature). |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 16:33 |
about Nusselt number: local or average? | lbmagis | FLUENT | 10 | November 27, 2012 11:23 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 10:01 |
Can Fluent calculate local Nusselt # | Jake Lee | FLUENT | 10 | April 17, 2003 21:48 |
Fluent formula for Nusselt number | Alan | FLUENT | 1 | May 29, 2001 13:50 |
