Convergence Problem in Axisymmetric Periodic Flow |
February 8, 2014, 12:12 |
Anj
Rep Power: 12 |
Hi everyone,
I am modelling a periodic flow for a 3D pipe, using an axisymmetric model. The flow is to be in the Z direction, with half-width (or radius) of 3 m. The Reynolds number is 34,132 and the working fluid is air. This gives my inlet velocity of 0.081 m/s. I set the turbulence intensity as 4.3% and turbulent length scale of 0.42. I have a problem, however, in obtaining convergence. My current convergence criterion is 1e-06 for all the variables. With the initialization values below: My convergence plot is: I have tried to run a full 3D pipe periodic flow as well. For my initial mesh, I managed to obtain convergence, however, as I refine it further (by increasing the bias factor from 10 to 20), now it won't converge. Not sure what's going on! So any comments/feedbacks will be greatly appreciated! Thanks so much in advance for your help! Last edited by atheresia; February 8, 2014 at 12:16. Reason: Forgot to attach the images! |
February 9, 2014, 05:13 |
Alex
Rep Power: 49 |
2D axisymmetric domains in fluent must have the x-axis as symmetry axis.
Additionally, for translational periodic flows with a very short streamwise extent, it is not unusual to take 10e5 or even more iterations to converge. 10e-6 for the residual values may still be too loose as a convergence criterion in this case. Make sure to double-check convergence with some other quantity like wall shear stress. Last edited by flotus1; February 9, 2014 at 16:47. |
February 9, 2014, 18:03 |
#3 | |
Anj
Rep Power: 12 |
I've just tried it in xy plane and it converges now!! Thank you! I am not sure, however, how to 'double-check convergence' with other quantity like wall shear stress.. I'm still new to CFD so I would really appreciate it if you would share some guidelines/resources on this? :-) Many thanks!! |
February 10, 2014, 04:00 |
Alex
Rep Power: 49 |
The basic idea is that you should never judge convergence based on the value of some residuals alone.
They are a good indicator, but sooner or later you will run into trouble if you rely on them too much. The absolute minimum for a simulation like yours is to set up a monitor point to monitor the average wall shear stress at the pipe wall. These two links have lots of valuable information on this topic: http://www.cfd-online.com/Forums/flu...nvergence.html http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F |
3D Swirl flow in the pipe: convergence problem | Sachin U. Nimbalkar | FLUENT | 5 | December 22, 2016 02:34 |
Convergence problem with flow facing a backstep | GM_XIII | OpenFOAM Running, Solving & CFD | 14 | March 27, 2014 04:56 |
3D Compressible Nozzle Flow Convergence Problem | mep10jl | FLUENT | 2 | July 30, 2013 18:09 |
Rotating wall velocity boundary condition for axisymmetric flow problem | diwakaranant | SU2 | 1 | March 24, 2013 00:45 |
Problem with periodic boundary layers | Phil | FLUENT | 15 | October 2, 2000 15:56 |
