Low Re Flow over S1223 Airfoil
Like Tree4Likes
  • 2 Post By kesari
  • 1 Post By AidealZohary
Old   February 6, 2014, 01:00
Question Low Re Flow over S1223 Airfoil
Dinesh Babu
devanson is on a distinguished road
Send a message via AIM to devanson Send a message via MSN to devanson Send a message via Yahoo to devanson Send a message via Skype™ to devanson
Dear Friends,
I need your help. Currently, I am doing a CFD validation cases on 2D airfoil at low Reynolds number (Range 50,000 to 200,000).
Airfoil chosen : S1223 (available on www.airfoiltools.com)
Reynolds no : 200,000
Mesh : Structured mesh using ICEM CFD (With boundary layer mesh having first cell height of y+=1)
Solver : ANSYS Fluent
Turbulence Model : Spallart-Allmarus
The problem is the lift curve (Coefficient of lift vs angle of attack) is way off from Experimental curve). Max Cl (Coefficient of lift) is supposed to be 2.3 at angle of attack 15. But I am getting 1.9 at 13 degree.
Another case: with Flat plate. My Max Cl is deviating away from Experiment value. But the Drag and moment curve are matching close to experiment.
Why I am getting this deviation? Is there a good approach to deal with Low Re flow?
Dinesh Babu
CFD Engineer
devanson is offline   Reply With Quote
Old   February 9, 2014, 09:12
Sriram Krishnaswamy
kesari is on a distinguished road
Hey Dinesh,
As a part of my project I had done an exhaustive analysis of NACA4421 airfoil and also checked NACA0012 airfoil.
I found out that however good the ICEM CFD mesh is, it consistently underestimates the Cl values by 10% compared to an ANSYS mesh. I still haven't figured out why but this seemed to be the case for all RANS 2 equation turbulence models.
This might be the same problem you are facing. Try it with a good mesh generated with the help of ANSYS Meshing and check if it's still underestimated.
Will update as soon as I figure out a solution.
Cheers,
Sriram
devanson and Dronzer like this.
kesari is offline   Reply With Quote
Old   February 22, 2014, 10:00
Tushar K Herle
Tushar K Herle is on a distinguished road
Actually i am also working on the same S1223 aerofoil, nearly same renolds number and same model. I ve used a mesh generated using Gambit. It is hybrid mesh with quadrilateral mapped mesh around the aerofoil and free mesh in far field. Even i am facing the same problem.
At small angle of attack i am getting the same values as xfoil but as the angle of attack increases the deviation from the xfoil values too is increasing..
-Tushar
Tushar K Herle is offline   Reply With Quote
Old   February 22, 2014, 13:32
farzadpourfattah
farzadpourfattah is on a distinguished road
hi.
i suggest you use Transition kw (4 equations) model in fluent for modeling Low Reynolds number, I validate flow around SD8020 with experiment data in different AOAs.
farzadpourfattah is offline   Reply With Quote
Old   July 10, 2014, 01:33
Default Any Solutions?
Dinesh Babu
Hi Friends,
Still facing the same issues? Any solutions?
I tried with K-O 4 equations & V2F. Facing difficulties in converging the solutions. :-(
Dinesh Babu
CFD Engineer
Old   July 10, 2014, 05:48
Default Low Reynolds
farzadpourfattah
yes good convergence depend on boundary layer mesh.
can you detect the bubbles on airfoil?
Old   October 10, 2014, 02:19
Dinesh Babu
I created a vry fine mesh with wall y+ <=1. But still facing the issue. Using S-A, case is converged. But Lift & drag values differ from Windtunnel data.
Dinesh Babu
CFD Engineer
Old   October 10, 2014, 18:36
Default hi
farzadpourfattah
hi
change your Turbulence model to Kw-sst or Transition kw (4 equations) model.
Old   March 3, 2021, 16:38
Aideal Zohary
AidealZohary is on a distinguished road
Hi, this is an old thread. But if anyone is still interested to run a simulation on the S1223 airfoil, please take a look at:
Numerical Investigation on the Pressure Drag of Some Low-Speed Airfoils for UAV Application.
https://doi.org/10.37934/cfdl.13.2.2948
Unsteady 3-equation k omega intermittency SST was used. Good comparison with XFOIL and experimental data. Transition features also shown through cf and cp plots.
devanson likes this.
AidealZohary is offline   Reply With Quote
Old   September 2, 2021, 03:05
Aideal Zohary
Learn how I designed the mesh here:
https://www.youtube.com/watch?v=qZRqBu9Ss2U
airfoil analysis, fluent 14.5, low reynold's number, spalart allmaras
Cavitation Simulation of low mach flow over 2D airfoil Harkot FLUENT 3 October 1, 2013 12:04
How to model suction flow in an airfoil in Fluent Davy FLUENT 4 October 23, 2006 04:56
About the invisd flow around an airfoil maximus Main CFD Forum 1 July 16, 2005 16:04
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
CFD code for very low Re Flow Raj Main CFD Forum 2 May 31, 1999 23:06
