UDF for pressure outlet backflow total temperature
Like Tree6Likes
  • 1 Post By MrDaimon
  • 3 Post By A CFD free user
  • 2 Post By macfly
Old   January 27, 2014, 04:47
Default UDF for pressure outlet backflow total temperature
Gilberto Santo
MrDaimon is on a distinguished road
Hi all,
I am trying to solve a solidification and melting problem using Ansys Fluent 13. My problem is: I have a mass of PCM (Phase Change Material) which is warmed up by a flux of oil in a heat pipe. When melting occurs, I set the density of the PCM to reduce, so I need an outlet in the volume occupied by PCM to make mass flow out of domain. Obviously convective movements are important in my simulation, so I need to know if there is a way to set the backflow temperature equal to the temperature in the cell near the pressure outlet, maybe using a UDF. Can anyone help me?
I hope I've been clear.
Regards
adnanghreeb likes this.
MrDaimon is offline   Reply With Quote
Old   January 27, 2014, 14:48
A CFD free user's Avatar
A-A Azarafza
A CFD free user is on a distinguished road
Hi guy,
I think, it's possible. First, try to get the temperature in cells near the pressure outlet using a DEFINE_ADJUST general purpose macro. Then store it in a C_UDMI and recall it by a DEFINE_PROFILE macro for the face thread.
MrDaimon, adnanghreeb and zimao like this.
Regard yours
A CFD free user is offline   Reply With Quote
Old   January 28, 2014, 03:28
Default Thanks
Gilberto Santo
Thanks man! Unfortunately I'm not so good using that kind of macro... Can you tell me more about it? How would you write it?
Old   January 29, 2014, 09:42
François Grégoire
macfly is on a distinguished road
I got exactly what you want, did that in the past
Did you look on the udf forum?
 #include "udf.h"
 real T_mean;  /* defined outside because will be used in multiple DEFINE macros */
 DEFINE_ADJUST(adjust, domain, t)
 real T_tot;
 real u;
 real counter = 0;
 face_t f;
 int ID = 20; /* outlet ID displayed in Fluent boundary conditions panel */
 Thread *thread;
 thread = Lookup_Thread(domain, ID);
 begin_f_loop(f, thread)
 u = F_U(f, thread); /* x velocity */
 if (u >= 0) /* if fluid is going out... */
 T_tot += F_T(f, thread);
 counter = counter + 1;
 end_f_loop(f, thread)
 T_mean = T_tot/counter; /* arithmetic mean T of outflow */
 DEFINE_PROFILE(T_backflow, thread, position)
 face_t f;
 F_PROFILE(f, thread, position) = T_mean;
- modify the velocity component and the if condition depending on your geometry...
- If I remember well, I think you have to interprete the udf before each simulation to reset the variables
- It does an arithmetic mean of the outgoing fluid temperature, not accurate if your mesh is not uniform at the outlet and temperature varies a lot
- If I were you, I'd modify the code for an area-weighted average of T of the outgoing fluid at the boundary
A CFD free user and zimao like this.
macfly is offline   Reply With Quote
Old   January 29, 2014, 10:05
Gilberto Santo
Thank you soooo much!
Old   January 29, 2014, 12:05
Default ANSYS Fluent
adnan
adnanghreeb is on a distinguished road
Dear friends, I have question in fluent please.
I used ICEM for simulate heat transfer in kiln, then export to fluent, actually in this time i run my program without combustion.
can get converge at residual e-2 but with not good report about mass net, as same time reasonable result.
so take more for residual until e-4 , also get converge but not reasonable result and in this case report mass excepted?
any suggest, thanks in advance
adnan
adnanghreeb is offline   Reply With Quote
Old   January 29, 2014, 12:13
François Grégoire
adnan
I think you wanted to start a new thread. Please start a thread with a specific title about your problem, not the most general title like 'Ansys Fluent'.
Old   January 29, 2014, 14:27
Gilberto Santo
 #include "udf.h"
 real T_tot;
 real u;
 real counter = 0;
 face_t f;
 Thread *thread;
 face_t f;
Did you have the pressure outlet on the right side of domain? I have it on the left, so maybe I should consider the velocity in the opposite direction... Am I right?
Old   January 29, 2014, 14:29
François Grégoire
yes that's it, plot the velocity you'll see what's negative or not
Old   February 3, 2014, 09:16
Gilberto Santo
Man, I'm sorry but it doesn't seem to work I used the ID of my outlet, change the velocity direction but it doesn't work... It sets the backflow total temperature to 0, even if I initialize my case with 423.15 K (which is my initial condition). My geometry is planar (2D), not solid, but I am using an assialsimmetry condition... does it affect the UDF? Was your UDF written for a 3D geometry?
Old   February 3, 2014, 13:16
François Grégoire
- I assume you interpreted the udf and set the backflow T at the outlet.
- But did you hook the DEFINE_ADJUST? (Define\User-Defined\Function Hooks...\edit Adjust and select 'adjust'
The udf works in 2D or 3D. I don't think that the axial symmetry boundary affects the udf.
Old   February 4, 2014, 03:10
Gilberto Santo
I didn't know how to use the "adjust", I'm sorry I never used this kind of UDF before, so thank you so much! I'm now tryin to do what you told me.
Anyway, does this UDF work in steady and transition conditions too?
Old   February 4, 2014, 11:11
François Grégoire
hooking is like telling Fluent to use the udf it interpreted (or compiled), see the Ansys Fluent UDF Manual
yes it will work for steady or transient cases
Old   June 23, 2017, 01:45
jjfm20 is on a distinguished road
I'm trying with this UDF but it stops when reaching about the 30 iteration (Diverges), and I'm still not sure why, can some help me, what do I need to check for that to work well? I have to tell, this only happens when I use the Coupled Pseudotransient Method, the thing is, I do need to use this solution method.
Hope you can help me.
Regards.
jjfm20 is offline   Reply With Quote
backflow, convection, pressure outlet, total temperature, udf
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 08:15
Increasing of total temperature Roland R CFX 4 March 29, 2018 04:08
Inlet won't apply UDF and has temperature at 0K! tccruise Fluent UDF and Scheme Programming 2 September 14, 2012 07:08
non constant outlet temperature amir7 FLUENT 0 April 9, 2012 21:12
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
