Wind Turbine Air Flow Analysis
Like Tree1Likes
  • 1 Post By blackmask
Old   January 23, 2014, 14:24
Lightbulb Wind Turbine Air Flow Analysis
NightHawkRaven is on a distinguished road
I'm trying to model the air flow pattern around a wind turbine using ANSYS Fluent. Can anybody list out a few tutorials for beginners in this regard ?
Thanks
Night Hawk Raven
NightHawkRaven is offline   Reply With Quote
Old   January 23, 2014, 21:32
blackmask will become famous soon enough
It depends.
If you want to study the aerodynamic properties of the blade, you could use the MOVING FRAME technique.
To study the wind turbine wake, you could replace the turbine array by PRESSURE JUMP or POROUS MEDIA.
If you want to study the details of the near wake of a turbine, you probably need to use the SLIDING MESH. It is time consuming because you need to do transient analysis for a long time ( several turbine rotation periods). You need a solid answer for "why should I do it" before you start this one.
flotus1 likes this.
blackmask is offline   Reply With Quote
Old   January 25, 2014, 04:28
Smile
like.no.other
like.no.other is on a distinguished road
Hi
You can study this tutorial in ANSYS FLUENT:
Using Moving Reference Frames and Sliding Meshes
This example have two strategies:
Part 1: steady-state solver, defining the motion using Moving Reference Frames (MRF)
Part 2: transient manner, moving the mesh using Sliding Meshes
www.CFDiran.ir
like.no.other is offline   Reply With Quote
Old   January 29, 2014, 15:45
Hi blackmask,
Which of these methods would be more appropriate or closely match the idea of simulating the air flow pattern ?
Old   January 29, 2014, 21:10
Wind tunnel experiments more or less lay emphasis on near wake pattern. When they talk about flow pattern, most of the time they are describing tip/root vortex. Wind resource assessment on the other hand always concerns about the mutual influences of wake on wind turbine array. Flow pattern in this regard means wake expansion, wake mixing, wake merging, etc.
air flow, air flow simulation, ansys fluent, wind turbines
fluent analysis of wind turbine er_ijaz FLUENT 0 May 1, 2013 05:55
Vertical Axis Wind Turbine atorninc Main CFD Forum 3 March 6, 2013 05:38
Unsteady flow over a savonius wind turbine Robyfood Siemens 9 March 14, 2012 10:41
Tutorial related to flow analysis of Hydro turbine Sanjay Jain FLUENT 0 April 10, 2008 10:09
radial turbine flow analysis ME Siemens 1 August 16, 2007 04:06
