January 21, 2014, 09:40 |
S2S Model
Rep Power: 14 |
In the process of calculating view factor
I have some points can't understand a) what 'faces per surface cluster' means b) how do we decide which surface is not necessary for view factor calculation Thanks in advance for your help |
January 21, 2014, 10:40 |
Flavio
Rep Power: 15 |
Hello itsme_kit,
a) Faces/clusters is the number of cell-faces that are grouped in a cluster: for example, if you set 100 faces/clusters every cluster will have 100 faces (100 elements of your mesh); with this option you are able to decrease computational cost. b) you need to include in view-factor calculation all the important surfaces of your system: of course there isn't a general rule, it depends on your problem. I suggest excluding smallest surfaces and remember that if you have coupled surfaces (solid-fluid interfaces for example, with shadows-wall), you have to include only the face of the fluid in the view-factor calculation (so you can exclude solid faces) Regards
Bionico |
January 21, 2014, 10:52 |
#3 | |
Rep Power: 14 |
Thanks for your explanation, Bionico Just expand first question a little further It seems that the more number of face/cluster we set up, the less accurate results we will get. Does it make sense? |
January 22, 2014, 02:28 |
Flavio
Rep Power: 15 |
You're right: bigger the cluster is, less accurate the calculation of radiating heat flux is.
Imagine the clustering like the meshing: increasing faces/cluster will generate a coarser resolution of radiating heat flux Regards
Bionico |
I need help about radiation (surface to surface- s2s model) | miyage218 | FLUENT | 3 | March 31, 2021 00:00 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
View Factor on S2S radiation model | Kristofer. | FLUENT | 1 | May 31, 2013 08:10 |
Some problems about S2S and DO model | Dorasemon | FLUENT | 2 | April 1, 2013 10:51 |
how to write and read view factor file in radiation model S2S | chhanwal | FLUENT | 1 | March 25, 2009 10:54 |
