Ahmed body -Drag coefficient not converging!! |
January 12, 2014, 10:50 |
Rep Power: 12 |
Hi All,
I am trying to simulate flow around an ahmed body with 35 degree slant.I have been following some tutorials online , but my drag coefficient is not converging.Below is an overview of the meshing and simulation details I have used. MESHING Total number of elements -2.9 million approx Min size-1mm Max size-250mm Minimum edge length-50mm I have added face sizing and rear body sizing with 8mm element size 5 Inflaton layers for the body and road with growth rate of 1.2 , following smooth transisition SIMULATION Boundary condition:- inlet velocity-40m/s ,outlet -atmospheric presure and no slip for road and body, rest all symmetry planes Pressure based solver,steady state realisable k-e ,non-equillibrium wall functions Coupled scheme, gradient- least square cell based First order upwind for momentum,k,e for first 100 iterations then changed to second order. courant number-50, relaxation of 0.25 for momentum,pressure and 0.8 for rest standard initialization based on velocity inlet i have done about 700 iterations and my drag coeffiecient seems to be increasing and decreasing around .28xx I have attached a snapshot of the residuals If someone could please give me some insight to where i went wrong,it would be really appreciable. Thanking you, sam92 ahmed_mesh.png ahmed1_mesh.png cd-history.txt residuals.jpg |
January 12, 2014, 22:59 |
Rep Power: 24 |
Generally oscillation is a typical behaviour of 2nd order schemes when gradients are not resolved good enough. You can try to refine the mesh in areas of high gradients.
Looks like you followed the detailed tutorial for ahmed body in workbench on youtube . Also check FARs tutorial especially for hexa meshing of ahmed body. http://www.youtube.com/watch?v=2baEa...ature=youtu.be This should give you a way better mesh. Further I personally would start with hybrid initialization, default URFs, double precision solver and use k-omega-sst model. Further iterate way more than 700 iterations. |
January 13, 2014, 05:35 |
Rep Power: 12 |
Thank you for your reply kad.
I'll try to refine my mesh near the regions of high gradients and see how further iterations go. Should i use default URF's or go ahead with the URF's I was using? Thanks a lot |
January 13, 2014, 09:39 |
Rep Power: 24 |
I would try default URFs first. If your solution is not converging you can change them later. As mentioned before I would also switch to k-omega-sst turbulence model. The k-epsilon model does not perform well in areas with stagnating or separating flow. Both of these phenoms occur in your model and should have significant influence on the drag value. .
January 13, 2014, 23:31 |
Rep Power: 14 |
Did you have a look at the solution?
It is probably not really a convergence problem. If the flow around your body is just transient (vortex street etc.) your residual won't go down at all. You could suppress these effects with relaxation, but that actually makes your solution wrong. For example have a look at a cylinder with and without Karmann vortex, the difference for the drag is around 45%. (around 1.3 in transient and 0.9 in steady I think). Anyway consider maybe using a transient simulation and average the solution. I'd be interested if you can solve it with that so please let me know if you tried it Cheers |
January 14, 2014, 08:54 |
Rep Power: 12 |
Thanks for your suggestions beer
But in the tutorial's online, a steady state simulation was performed on ahmed body(25 degree slant) with realisable k-e model and the obtained drag coefficient was within 5% of the experimental value. The only difference is that i am doing the simulation on a 35 degree slant one,rest all the steps are the same as the tutorial. I've found that for the 35 degree case there is detached flow over the slant compared to attached flow for 25 degree case.Is that why the k-E model is failing in my case? I'll try doing a transient simulation, if someone could share their transient simulation setup details, it would be really helpful. Thanks a lot sam92 |
January 14, 2014, 09:28 |
Rep Power: 14 |
Hm, ok this is still possible. Detachement is exactly what I mean. After an detachement you have recirculation which can lead to transient effects which affect your convergence. But I can't really say from here if this is the problem. Like I said, just try a transient one with 10-20 inner iterations and you should see after a few iterations if the timesteps converge. If yes, it is very likely that your flow is just "too transient" for your steady state solver.
If not you have to dig a little bit more. It could be still also the mesh, the boundary conditions, solver parameter etc. etc... Cheers |
January 14, 2014, 09:29 |
Rep Power: 14 |
Oh btw: Is the model 3D or 2D?
January 14, 2014, 10:22 |
#9 |
Alex
Rep Power: 49 |
I bet 10$ that the simulation will converge once you run more than 700 iterations
January 14, 2014, 15:00 |
#10 |
Rep Power: 12 |
The model is a 3d one.
As flotus 1 said ,I'll iterate it further to see if the drag coefficient converges . Also,As kad pointed out, i'll look into whether a mesh refinement at areas of high gradients solves the problem and let u know. If both the above doesn't work, I guess a transient simulation or using a different turbulence model(like SST) is the only option I have. Thanks a lot sam92 |
Drag Coefficient for Ellipse Form (2D) | Ketut Utama | Main CFD Forum | 8 | December 11, 2014 12:03 |
Ahmed body drag coefficient | jackwabbit | STAR-CCM+ | 2 | September 2, 2013 05:36 |
Drag coefficient on a 2-D cylinder | haghgoo_reza | OpenFOAM Running, Solving & CFD | 0 | April 25, 2013 17:35 |
How find Drag coefficient of a body with ANSYS CFX | Jhonathan | CFX | 2 | October 2, 2008 19:07 |
to find drag coefficient of an ogival body | ace | FLUENT | 2 | January 27, 2004 11:14 |
