non-uniform initial temperature
Like Tree1Likes
  • 1 Post By flotus1
Old   December 10, 2013, 11:08
Default non-uniform initial temperature
Steinar
grjoti is on a distinguished road
Hi
I have a file with x, y and z coordinates and corresponding temperatures for each point.
Here is a part of that file:
x y z Temp
0.69725 0.68104 0.012542 276
0.34184 0.62185 0.011765 276
1.1473 0.60445 -0.40537 275.69
1.1468 0.56266 -0.31188 275.69
1.1476 0.6241 -0.70874 275.63
0.75318 0.64313 -0.98494 276.01
I have to use that data as initial temperature data. I have tried to use patch but that only works for a few points as I understand it. Unless I use a custom field function however I do not know how to implement my file into the function. The file I have consists of over 700.000 data points and was created using the element data from my mesh. I did measurements and used the measurement data to interpolate the temperature onto the entire mesh.
Now I have a very large initial temperature data file with the temperature value in each element but do not know how to read it into Fluent.
If i could somehow read the data file into Fluent and use the data from it as the initial temperature.
All help will be greatly appreciated.
grjoti is offline   Reply With Quote
Old   December 10, 2013, 12:35
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
Fluent can do the interpolation for you.
Have a look at the "file->interpolate" menu point.
Yet it needs a slightly different file format, but since you were able to interpolate the data yourself I am sure that you can figure out how to change the format accordingly.
grjoti likes this.
flotus1 is offline   Reply With Quote
Old   December 11, 2013, 05:52
Steinar
Thank you!
This is exactly what I was looking for. I don't know how I could have missed that Fluent can interpolate for me.
Thank you again.
initial temperature, non uniform
Floating point exception error Alan OpenFOAM Running, Solving & CFD 11 July 1, 2021 22:51
parallel run is slower than serial run (pimpleFoam) !!! mechy OpenFOAM 18 August 17, 2016 18:19
Interfoam blows on parallel run danvica OpenFOAM Running, Solving & CFD 16 December 22, 2012 03:09
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
Unknown error sivakumar OpenFOAM Pre-Processing 9 September 9, 2008 13:53
