Hybrid Initialization Error
Like Tree1Likes
  • 1 Post By kuzma169
Old   December 5, 2013, 06:13
Default Hybrid Initialization Error
Persil is on a distinguished road
I want to simulate the flow through 2 stages of a gas turbine and therefore built a model like this: mixing plane=mp
vane1 -> mp -> blade1 -> mp -> vane2 -> mp -> blade2
energy equation: on, k-e-model
after setting the boundary conditions, solution methods (SIMPLE, Standard 5x first order) and controls (reduced the under relaxation factors to increase them later on...) I wanted to initialize with hybrid initialization. There I get the error:
Eror: Specific_Heat_by_T_Integral: invalid lower bound, T0 <= 0.
Error Object: #f
I don't know where to look for fixing this error: maybe changing the boundary conditions at the outlet? Thankful for any feedback
Persil is offline   Reply With Quote
Old   December 5, 2013, 12:47
Zaktatir is on a distinguished road
look in your material properties and specially the definition of heat capacity i would say regarding the failure message
Zaktatir is offline   Reply With Quote
Old   December 5, 2013, 12:54
thx for the reply: I will try that tomorrow and give feedback, what happend
Old   December 6, 2013, 06:22
I took a look at the material settings and changed the given to piecewise-linear with some modifications but that did not solve the problem. The error still occurs...
instead of initializing the 2 stages at once, I will try to initialize the components separetely in another cas-file each... mabye this way I can figure out the right boundray conditions
Old   December 6, 2013, 06:34
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
Smells like you didnt use SI units (Kelvin temperature scale) to specify a temperature dependency.
Try using constant material properties to see if this is the source of error.
flotus1 is offline   Reply With Quote
Old   December 6, 2013, 07:43
well I kept the default unit settings, so SI: kelvin for temperature was enabled from the beginning
could I initialize successfully if I adjust the under relaxiation factors? I thought until now, that you would change them between simulations to reach better convergence...
Old   December 6, 2013, 07:59
flotus1's Avatar
Alex
The under-relaxation factors have nothing to do with the initialization, so changing these wont help.
I didnt mean that you changed the default setting for the units.
How EXACTLY did you specify the specific heat of the material? And again, try a constant value here to make sure that this causes the error.
Old   December 6, 2013, 08:59
ok, was just making sure
you can see the material settings for the specific heat in the attachment
I also tried initializing with just the specific heat as constant and kept the rest as it was before... but that still generated the error from before
Old   December 6, 2013, 09:05
flotus1's Avatar
Alex
So what about the standard initialization?
Old   December 6, 2013, 09:45
same error with standard initialization
could you explain me, what this error means? for me it sounds like that due to some wrong boundary conditions or related the temperature falls below 0 K, which is something you don't want to see displayed...
Old   December 6, 2013, 11:51
I found the problem:
whilst modeling I created periodic boundaries via mesh/modify/mp but did not check the grid afterwards... so I didn't notice that one rotation angle was defined in the wrong direction.
fixing that (grid/repair-improve/repair-periodic) hybrid initialization went smoothly
Old   December 19, 2018, 08:59
kuzma169 is on a distinguished road
Error Object: #f
It's result of having warpage element faces. Search for bad elements . You need finding wrong surface orientation, wrapped element face or negative - neglected volume etc. It's my opinion founded to my experiences.
Best regards.
Cheerio!
Dodul likes this.
kuzma169 is offline   Reply With Quote
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 12:39
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 08:24
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 13:34
POSDAT problem piotka STAR-CD 4 June 12, 2009 09:43
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
