November 26, 2013, 12:48 |
Transition flow in a heat pipe
Gilberto Santo
Rep Power: 14 |
Hi everybody,
I am simulating (using Fluent 12.1) a flux of oil in a heat pipe. Obviously the turbulence of the fluid influences the heat flux generated. I have Reynolds = 1911, which turbulence model is the best to use in this case? Should I use the laminar model? If no, which transition model is the best for my application? I hope I've been clear. Thank you all! |
November 26, 2013, 17:40 |
Rep Power: 17 |
you have to make a sensitivity analysis between laminar/ and low-Re turbulence model.
I would use low Re turbulence models: SST with Low-Re correction, or better the transitional ones in Fluent. There other k-epsilon based turbulence models which are low-Re ones (access over TUI) your yplus hast to be in the viscous sublayer around 1-max 5 expansion in the boundary layer 1.1-1.2 |
convection, heat pipe, reynolds number, turbulence and laminar |
Pipe flow with obstacle - HELP | Min | FLUENT | 6 | January 31, 2017 15:28 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
setup problems - LES pipe flow with cyclic BC (1) and direct mapped inlet (2) | florian_krause | OpenFOAM | 22 | June 13, 2013 22:25 |
CFX fails to calculate a diffuser pipe flow | shenying0710 | CFX | 7 | March 26, 2013 05:13 |
Flow around pipes - heat transfer coefficient on the wall of pipe | doodek | Main CFD Forum | 2 | November 23, 2009 09:48 |
