November 14, 2013, 10:26 |
how to capture free surface cells?
anonymous
Rep Power: 13 |
Dear Colleagues,
I would be grateful is someone advise me how I can capture the free surface cells (cells on free surface). I use VOF model in ANSYS Fluent and I need to set up thermal conditions for the free surface between two fluids. As i understand, the free surface is the surface with 0,5 volume fraction value (of one of the fluids in the domain). So, I made an attempt to capture iso-value of volume fraction between 0,4 and 0,6 but no cells are marked (adapt >iso-value...). However, I can capture the iso surface 0,5 (surface>iso-surface)which is in fact the free surface I am looking for. However, I cannot set up boundaries for this iso-surface 0,5 as it doesn't appear in the list of zones (boundary conditions) or in the zones to patch (solution initialization). How could this be done? I would be grateful for any suggestions! |
June 10, 2015, 03:18 |
wanli
The same problem occurred to me, and I am trying to solve this problem. Did you solve it?
free surface, iso-surface/line, vof |
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel | colinB | OpenFOAM Meshing & Mesh Conversion | 14 | December 12, 2018 09:07 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 09:54 |
free surface modelling using VOF | sci | Main CFD Forum | 10 | August 29, 2012 08:43 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 20:43 |
Multiphase flow. Dispersed and free surface model | Luis | CFX | 8 | May 29, 2007 19:13 |
