Turbulence intensity too high on the inlet
Like Tree1Likes
  • 1 Post By trollreign
Old   November 5, 2013, 12:07
Default Turbulence intensity too high on the inlet
Laszlo A.
trollreign is on a distinguished road
I am a beginner (or more like a restarter) of CFD.
I am modelling atmospheric boundary layer flow, trying to simulate the flow around wind turbines. I set an inlet boundary condition with incoming flow velocity of 10m/s and turbulence intensity of 10%. The model is a 2D top view. The turbines are large (107m diameter), the flow domain is 1500x3000m, the mesh has roughly 70,000 elements (refined around the turbines). The turbines are modelled in this very simple first try as fans with a pressure drop determined from a thrust coefficient of 0.7 on the turbines (or for those familiar with the actuator disk concept an axial induction factor of ~0.3). I am using a k-epsilon model with the standard parameters in Fluent.
The problem I am facing is that even though I set the inlet turbulence intensity between 10-15%, the solution converges, but a contour plot of turbulence intensity shows TI values between 60% and 200% across the simulation domain, including the inlet.
I may be missing something here, but I do not understand where these high TI values are coming from? Must be something with the definition of the k-epsilon model and/or the definition of turbulence intensity and turbulent length scale on the inlet. The length scale I am choosing is anywhere between 10m to 340.2m, I tried several scenarios but in each case the TI is very high.
Any help is appreciated.
ro_bb likes this.
trollreign is offline   Reply With Quote
Old   December 10, 2023, 22:10
Yizhi Fang
b060242 is on a distinguished road
See the link below:
Inquiry about turbulent intensity and turbulent length scale.
It may be a 'reference value' problem. You have to set the reference velocity the same as the inlet velocity to correctly calculate the turbulence intensity field.
b060242 is offline   Reply With Quote
fan boundary condition, k-epsilon model, length scale, turbulence intensity
How to define the turbulence intensity and mixing length at an outlet (for k-eps)? david39 OpenFOAM Running, Solving & CFD 6 February 2, 2011 04:01
High turbulence intensity wenfengxie FLUENT 1 April 16, 2010 13:00
High Turbulence Intensity Problem bwg FLUENT 1 January 13, 2010 14:09
Turbulence intensity BC Ralf Schmidt FLUENT 3 June 30, 2006 05:17
Turbulence Intensity Vs CFD Simulation Apple L S Chan Main CFD Forum 3 December 15, 1998 18:28
