How to enable Singhal Cavitation Model in Fluent v14.5 |
October 24, 2013, 10:18 |
Sarang
Rep Power: 13 |
I am working on Cavitation problem in fluent v14.5 and wanted to use Singhal cavitation model as my fluid has some Noncondensable gases. Apparently I found only two cavitation models 1) Schnerr-Saucer 2) Zwart-Geber-Belamri but as per fluent theory guide, it has three cavitation models. Is there any TUI command to enable it. Any help is appreciated! regards, Sarang |
October 24, 2013, 11:08 |
Andrew Kokemoor
Rep Power: 14 |
From Fluent User's Guide, section 25.4.3:
To enable the Singhal et al. cavitation model, use the solve/set/expert text command and answer yes to use Singhal-et-al cavitation model?. The Singhal-Et-Al Cavitation Model option will now be visible in the Phase Interaction dialog box, under the Mass tab. Enable this option to include the Singhal et al. cavitation model. |
October 24, 2013, 11:21 |
Sarang
Rep Power: 13 |
Thanks a lot!
-Sarang |
February 1, 2016, 04:11 |
Luke
Rep Power: 14 |
i want only to say thank you to this useful information!
thanks! |
Can FLUENT model flashing liquids? | SWK | FLUENT | 9 | June 22, 2017 02:17 |
Is it possible to model natural convection in a 2D horizontal model in fluent | caitoc | FLUENT | 1 | May 5, 2014 14:32 |
DES model in Fluent | Jonas Larsson | FLUENT | 8 | March 12, 2013 07:36 |
Cavitation models in FLUENT | Mike1982 | FLUENT | 0 | August 3, 2010 05:40 |
Reynolds Stress Model in Fluent Vs CFX | Tim | FLUENT | 0 | December 6, 2005 23:03 |
