Why Fluent does not have 2-order Runge-Kutta scheme?
Like Tree2Likes
  • 2 Post By sbaffini
Old   October 16, 2013, 00:57
Default Why Fluent does not have 2-order Runge-Kutta scheme?
Jingchang.Shi
aerosjc is on a distinguished road
Sometimes we only need a 2-order Runge-Kutta scheme. A 4-order Runge-Kutta maybe give a strange solution.
Anyone knows?
aerosjc is offline   Reply With Quote
Old   October 16, 2013, 03:45
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
Not all numerical schemes are created equal. The 2nd order Runge-Kutta scheme has very different stability properties with respect to the 4th order one. More specifically, its stability region does not cut the imaginary axis, hence it is not well suited for convection dominated problems.
ghost82 and RodriguezFatz like this.
sbaffini is offline   Reply With Quote
Old   October 23, 2013, 21:32
Jingchang.Shi
But whydoes it have Explicit 2-order Runge-Kutta Time Integration Scheme in the commerical sofaware GASPex, produced by AeroSoft. Inc? Please enlighten me. Thanks
Old   October 24, 2013, 04:12
sbaffini's Avatar
Paolo Lampitella
Well, i didn't say the 2nd order RK scheme is impossible to use, just that it is not well suited for convection dominated flows. If you look at the code page:
http://www.aerosoftinc.com/gasp/features_main.php
you can notice that all the convection schemes are dissipative, hence you can't actually use the code in a way such that the eigenvalues are purely imaginary, which should be enough for the 2nd order scheme to work. I'm just guessing...
Old   October 24, 2013, 12:18
Jingchang.Shi
ok, many thanks! I will read some textbooks to get better understanding.
runge-kutta, time discretization
Fourth Order Runge Kutta time integration lr103476 OpenFOAM Running, Solving & CFD 45 November 10, 2022 03:36
Main advantage of using Runge Kutta of higher order? jakubstary Main CFD Forum 14 August 20, 2019 17:15
Accuracy problem of HO schemes on unstructured mesh, HO scheme gives 1st order result gemini Main CFD Forum 12 December 27, 2011 22:01
2nd order boundary conditions for 2nd order discretization? quarkz Main CFD Forum 30 December 26, 2011 08:12
Discretisation scheme in CFX-1st or 2nd order? Pete CFX 10 January 12, 2005 13:48
