Applying heat flux at mesh/wall interface for a solid-fluid heat transfer? |
September 21, 2013, 02:00 |
Nitin
Rep Power: 13 |
I have made the model such that the fluid is flowing b/w two solid slabs as shown:-
______________________ solid 1(glass) ------------------------- <--mesh interface fluid -------------------------- <--mesh interface(with heat flux) solid 2(insulator) _______________________ \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ <--insulated boundary I made the model in solid edge and exported geometry into meshing software.I named the interface walls as WALL-SOLID-1, WALL-SOLID-2, WALL-FLUID-TOP, WALL-FLUID-BOTTOM and meshed the geometry using default options.then i exported *.msh file into FLUENT and used mesh interface option FLUENT to couple the walls, but to do so I had to convert these walls to interface. Now I have to apply heat flux at interface b/w WALL-SOLID-2. and WALL-FLUID-BOTTOM.Could someone please help me, how to apply this heat flux? Any help is appreciated |
September 21, 2013, 07:34 |
#2 | |
sridhar
Rep Power: 16 |
physically those two are not Interfaces, those two are walls, if you give wall boundary condition fluent automatically generate wall shadow, At wall boundary you can give heat flux in thermal tab. |
September 23, 2013, 02:14 |
Nitin
Rep Power: 13 |
i have already tried it, but some reason Fluent is not generating wall shadow
September 23, 2013, 14:56 |
sridhar
Rep Power: 16 |
September 28, 2013, 05:55 |
Nitin
Rep Power: 13 |
hi, I solved the problem by converting the heat flux into equivalent heat generation and then providing this heat generation at the interface
September 28, 2013, 09:57 |
#6 | |
François Grégoire
Rep Power: 17 |
read this mesh in Fluent, it has coupled walls and you can apply a thermal boundary condition on those internal walls (wall:002 and wall:003) |
August 19, 2018, 15:50 |
emzifer
convergenceof natural convection prob. in cfx | cpkewat | CFX | 15 | January 31, 2014 07:29 |
Heat transfer between solid and fluid | Suyash26 | ANSYS | 4 | April 22, 2013 16:59 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
Enforce bounds error with heat loss boundary condition at solid walls | Chander | CFX | 2 | May 1, 2012 21:11 |
