Problem in using parallel process in fluent 14
Like Tree1Likes
  • 1 Post By jdrch
Old   September 6, 2013, 13:42
Default Problem in using parallel process in fluent 14
Tleja
Tleja is on a distinguished road
Hello everyone
I installed Ansys 14 at a computer with 16 CPU and 12G Ram.when I run fluent under 8 cpu, it runs correctly and the massage is:
Loading "C:\PROGRA~1\ANSYSI~1\v140\fluent\fluent14.0.0 \lib \fl114-64.dmp"
Done.
Welcome to ANSYS FLUENT 14.0.0
Copyright 2011 ANSYS, Inc.. All Rights Reserved.
Unauthorized use, distribution or duplication is prohibited.
This product is subject to U.S. laws governing export and re-export.
For full Legal Notice, see documentation.
Build Time: Oct 25 2011 13:11:27 Build Id: 10398
Loading "C:\PROGRA~1\ANSYSI~1\v140\fluent\fluent14.0.0 \lib \flprim1119-64.dmp"
Done.
Host spawning Node 0 on machine "mainserver" (win64).
You can press CTRL+C to stop the startup process!
WARNING: No cached password or password provided.
use '-pass' or '-cache' to provide password
Platform-MPI licensed for FLUENT.
Host 0 -- ip 192.168.0.147 -- ranks 0 - 7
host | 0
0 : SHM
Prot - All Intra-node communication is: SHM
ID Comm. Hostname O.S. PID Mach ID HW ID Name
host net mainserver Windows-x64 11588 0 552 Fluent Host
n7 pcmpi mainserver Windows-x64 10544 0 7 Fluent Node
n6 pcmpi mainserver Windows-x64 10308 0 6 Fluent Node
n5 pcmpi mainserver Windows-x64 12244 0 5 Fluent Node
n4 pcmpi mainserver Windows-x64 12200 0 4 Fluent Node
n3 pcmpi mainserver Windows-x64 12140 0 3 Fluent Node
n2 pcmpi mainserver Windows-x64 12108 0 2 Fluent Node
n1 pcmpi mainserver Windows-x64 12088 0 1 Fluent Node
n0* pcmpi mainserver Windows-x64 12068 0 0 Fluent Node
Selected system interconnect: default
Cleanup script file is C:\Users\hpc\cleanup-fluent-mainserver-11588.bat
but when I run it with more than 8 cpu, it doesn't run. and the massage is:
Done.
Done.
Host 0 -- ip 192.168.0.147 -- ranks 0 - 15
host | 0
0 : SHM
Cannot find license file.
The license files (or license server system network addresses) attempted are
listed below. Use LM_LICENSE_FILE to use a different license file,
or contact your software provider for a license file.
Feature: fluent
Filename: C:\PROGRA~1\ANSYSI~1\v140\fluent\license\win64\..\ license.dat
License path: C:\PROGRA~1\ANSYSI~1\v140\fluent\license\win64\..\ license.dat
FLEXnet Licensing error:-1,359. System Error: 2 "No such file or directory"
For further information, refer to the FLEXnet Licensing End User Guide,
available at "www.macrovision.com".
Feature: fluent-par
Feature: fluent-par
ANSYS LICENSE MANAGER ERROR:Not enough Fluent - HPC licenses 16/8.
Unable to spawn node: license not available.
Hit return to exit.
How to Solve it? Help me please!
Tleja is offline   Reply With Quote
Old   September 7, 2013, 03:32
jdrch is on a distinguished road
You get that error because Fluent uses per-process licensing (in most cases). Your current license covers 8 processes (cores), but not 16. You can either expand the number of processes in your license (expensive), or find out what the maximum your current license supports and use that.
Tleja likes this.
Find me online here.
jdrch is offline   Reply With Quote
Old   September 8, 2013, 10:27
Tleja
Thank you Mr. jdrch. Do you have the other method to crack Ansys 14 without using AP14_Calc. If somebody have the other method to crack Ansys 14 ,
Please Suggest me.
Old   September 13, 2013, 11:54
ghost82's Avatar
Rick
ghost82 will become famous soon enough
This forum is not a warez place.
Read rules.
Here you won't receive any help.
ghost82 is offline   Reply With Quote
problem of running parallel Fluent on linux cluster ivanbuz FLUENT 15 September 23, 2017 20:12
problem about periodic boundary condition in Fluent winnawinna FLUENT 0 December 29, 2010 00:32
Problem with Fluent Parallel DarrenC ANSYS 0 October 27, 2009 06:38
Fluent parallel license problem brothershuai Main CFD Forum 0 July 1, 2009 16:41
Fluent parallel poovanna FLUENT 0 March 24, 2007 00:22
