August 27, 2013, 09:56 |
Fluent does not launch from workbench
#1 | ||
I'm trying to run Fluent on my computer. I have installed a valid academic version of ansys 14.5.7 downloaded from their internet site, i have a valid license from a server machine but I have a problem to launch Fluent from workbench. I can use Design Modeler and make the mesh but when I click on the setup button to launch Fluent, it crashes and I get the following message: Quote:
Besides, the program CFD-Post does not launch (either from workbench or from start menu) and I get the following message: Quote:
Could someone help me please? Thank you |
September 3, 2014, 04:54 |
Michael Kruger
Rep Power: 12 |
Hi NickyNac.
I get the same error with CFD Post. Have you resolved the problem?
------------------------------------------------------- Michael |
September 11, 2014, 15:35 |
Hi Mich_k,
I am sorry but I did not find any solution. I suspected the firewall or the antivirus or an outdated driver but nothing worked. The customer portal could not help either. I had to use another computer. |
August 3, 2015, 05:19 |
Hi
윤영 최
i had this problem too..but now
i solve this problem to update java and window. i don't know why this problem disappear... but if you have this problem until now, i recommend update. |
November 13, 2015, 10:06 |
Win7 solution
#5 | |
vlg
Rep Power: 18 |
On Windows7 you should update the system via Update Center. I didn't perform updates since 2012, and it have resulted in 197 updates installed just now. Now, the connection to FLUENT from WB works! (works, at least for ANSYS Student v 16.2 ) |
February 20, 2017, 09:11 |
William Hamilton
having this exact same problem with windows 10, everything is up to date, can't start fluent at all, any help would be appreciated!
November 2, 2017, 13:25 |
Elgadari
Rep Power: 9 |
hi, I am also facing the same problem on windows 10. did you fix the problem yet?
November 2, 2017, 13:39 |
William Hamilton
From memory I dont think I did, i had to just use a different computer
April 13, 2018, 10:42 |
how to fix it?
#9 |
invincible
Rep Power: 9 |
License error
Fluent __ Dynamic Mesh __ missle silo launch | mu ke | FLUENT | 2 | November 14, 2018 12:24 |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 04:22 |
Time to open Fluent from Workbench | ResH | FLUENT | 0 | September 30, 2010 03:11 |
Master node in parallel computing only distirubtion | syadgar | FLUENT | 1 | September 8, 2009 17:41 |
how to launch fluent from C code | Hugo | FLUENT | 2 | May 23, 2007 18:11 |
