when use Interaction with Continuous Phase?
Like Tree1Likes
  • 1 Post By John
Old   August 14, 2013, 11:57
Default when use Interaction with Continuous Phase?
Astio Lamar
asal is on a distinguished road
Hello everybody.
I want to know until which particle sizes, ones can neglect the effect of particles over the flow field? or in another say until what particle sizes we can exclude the effects of the discrete phase trajectories on the continuous phase?
It is well known that if the particles are to small, then they don't affect the flow field and then it is not needed to enable "Interaction with Continuous Phase". But I want to know the size, if we assume that particles have water properties.
I am appreciate if some one can offer me any article regarding this.
thanks.
asal is offline   Reply With Quote
Old   August 14, 2013, 14:44
John is on a distinguished road
Originally Posted by asal View Post
Hello everybody.
thanks.
This is related to particle stokes number. http://en.wikipedia.org/wiki/Stokes_number
You can neglect the effect of particles over the flow field when Stokes number is far less than 1.
asal likes this.
John is offline   Reply With Quote
Old   August 16, 2013, 09:03
Astio Lamar
Hello!
well, thanks for your helpful reply.
As it is clear, the Stokes number is defined as:
Stk = \frac{\rho_{d} d_{d}^{2} U_{\infty}}{18\mu_{g} L}
\rho_{d} and d_{d} are the particle density and diameter, \mu_{g} is the dynamic viscosity, L is a characteristic dimension of the obstruction and U_{\infty} is the bulk velocity.
I want to calculate the Stokes number in a room, that particles are liberated from the people exist within the room. The inlet was placed at the ceiling level and outlet on the vertical walls. In this case which values should be assigned to L and U_{\infty}?
I cannot understand what should be considered as obstruction. for the bulk velocity, should I assign the inlet velocity, average velocity in the room, or what?
thanks.
Two continuous phases and one dispersed phase modeling using CFX creddy_trddc CFX 1 August 13, 2013 23:23
Two continuous phase and One dispersed phase Michael CFX 2 January 14, 2010 16:19
continuous and discrete phase coupling in fluids-HELP atmcfd Main CFD Forum 1 December 31, 2009 00:02
Phase Interaction Ardo A. FLUENT 0 December 19, 2008 08:05
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
