Draw the tangential, axial and radial velocity for flow section
Like Tree2Likes
  • 1 Post By Jim87
  • 1 Post By mjgraf
Old   August 11, 2013, 17:23
Default Draw the tangential, axial and radial velocity for flow section
Osamah Ali Al-Hashimi
Al-Hashimi is on a distinguished road
Hello everyone,
I’m trying to draw the tangential, axial and radial velocity for flow section, the velocity profiles I got is not symmetric while it should be symmetric on axis … I found in other post in cfd-online that they say “In cfx post go to turbo mode then define your rotation axis next click calculate velocity components. Now you can plot the variables you need
Kindly how can I change the rotation axis in cfd post? Do you think this will solve the problem?
Kind regards
Al-Hashimi is offline   Reply With Quote
Old   August 11, 2013, 18:33
Stephan Langenberg
Jim87 is on a distinguished road
Hope I understand you in the right way.
You can define new perspictive of your results in contours, vectors etc.
You can only use displaying of component x or y or z. (If you use x and y you have the radial components of you vector
You can export your cell velocity values with file-interpolate and marking the vectors and the region
Or was your question to redefine the coordiante system from carthesian to cylindrical coordinate system?
Al-Hashimi likes this.
Jim87 is offline   Reply With Quote
Old   August 11, 2013, 23:23
mjgraf is on a distinguished road
when you click the Turbo tab there is a button at the bottom to Define the global Rotation Axis.
mjgraf is offline   Reply With Quote
Old   August 12, 2013, 02:16
Thank you very much for the advice, but kindly why i get the error in the pic below?
I'm trying to define the rotation to be on Y axis ... should i change other components other than the global axis?
axial velocity, tangential velocity
Plotting Radial Velocity and Tangential Velocity in CFD Post ashtonJ CFX 5 July 13, 2015 03:49
asking plot of axial and radial velocity teguhtf ANSYS 1 August 4, 2014 13:51
tangential, axial and radial velocity in swirling Al-Hashimi FLUENT 1 June 23, 2013 11:30
Radial velocity and tangential velocity on centrifugal fan, johnnyp FLUENT 2 May 24, 2013 08:10
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 03:13
