"Y plus" very important!!!
Like Tree5Likes
  • 3 Post By behest
  • 2 Post By behest
Old   August 8, 2013, 16:28
Post "Y plus" very important!!!
Qube is on a distinguished road
Hi!
I need some information about the expected Y plus value for each turbulence model.
Please help me!!!
Qube is offline   Reply With Quote
Old   August 8, 2013, 16:38
Ali.E
behest is on a distinguished road
hello,
Y+ is very effective in the calculation, and the value may be 5-24 or 24-500 for RANS turbulence model. But it can be changeable for your simulation and results
behest is offline   Reply With Quote
Old   August 8, 2013, 16:57
thank u for your response but i need a detailed information, such as how much acceptable y plus for realizable KE?
Old   August 8, 2013, 19:31
Ali.E
Actually, every boundary layer is divided into three parts: 1-sublayer 2-buffer layer 3-log law layer. All RANS turbulent models estimate viscosity and this viscosity is also included of molecular and/or turbulent ones. The importance of y+ lies in the fact that which part the center point of a mesh situates. Therefore, turbulent model estimates viscosity due to that part. In the buffer layer, we cannot have a good anticipation, as a consequence, it makes a recommend to avoid a y+ value in buffer layer. I enclose a picture to give the points
yashganatra, Qube and Mason liu like this.
Old   August 10, 2013, 02:53
FHydro
flow_CH is on a distinguished road
Please explain more. Thanks
flow_CH is offline   Reply With Quote
Old   August 10, 2013, 07:48
my case study is a simplified car body and i want to use RKE or SST KW turbulence models. for more accurate results, how much should be y plus values?!
which one is correct? 30< y+ <300 or y+ <5 ?
Old   August 10, 2013, 09:15
Ali.E
Dear friend
The drag coefficient is depend to y+ value. I suggest to you to consider 30< y+ <300 initially; but if the results was not sufficient precision, then use another y+.
It has had an experience that the y+ <5 is achieved more accuracy
Dear saeed!
Old   August 10, 2013, 11:33
thank you so much!
cfd, turbulence modeling, y plus
Which hardwares for workstation are more important to do CFD analysis? caitoc Hardware 9 January 8, 2013 20:31
important problem new anne FLUENT 6 August 13, 2012 04:46
Important problems in CFD Mixo123 Main CFD Forum 8 June 30, 2012 13:38
Hard disk speed important to increase CFD computing speed? lawrencelaw Hardware 13 November 17, 2009 15:35
Help!search for some important paper fluideniro Main CFD Forum 0 January 10, 2004 04:10
