July 31, 2013, 11:54 |
RMS root mean square velocity Fluent
CC
Rep Power: 15 |
Hi all,
I want compare the root mean square velocity from my simulations with results from literature. I'm simulating a turbulent pipe flow with a low Reynolds k-e turbulence model in a steady state. From what i read i can obtain it in fluent if the problem is time dependent. As I'm simulating a steady state flow, can I obtain the RMS directly from Fluent? Regards |
July 31, 2013, 13:07 |
Alex
Rep Power: 49 |
With the k-epsilon model, the turbulent kinetic energy is the only estimator you have for the actual Reynolds stresses in the turbulent flow.
To obtain the individual components of the Reynolds stresses, You have to perform a simulation with a reynolds stress turbulence model or a LES. Among the transient statistics in fluent for a LES, you have the RMS-values of the fluctuating parts of the velocity components. |
July 31, 2013, 20:16 |
Yes, you can get root mean square velocity (also mean/average) in Fluent unsteady simulation. But you cannot get the different components of Reynolds stresses in RANS simulation.
August 29, 2022, 13:14 |
#4 | |
Rep Power: 6 |
Hello Far, what would be the best way to calculate the rms of the velocity when I got my transient simulation in Fluent? Thanks! |
August 29, 2022, 22:10 |
Lucky
Rep Power: 66 |
Enable the data sampling for time statistics, just click the box.
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 07:08 |
root mean square velocity | Far | CFX | 12 | June 1, 2016 09:58 |
Prob in rms velocity components, pls help.. | sakurabogoda | CFX | 5 | February 13, 2013 22:30 |
how to calculate rms velocity fluctuation after runtime | nati | OpenFOAM Post-Processing | 6 | February 7, 2013 09:42 |
Can RMS velocity even be smaller than mean velocity? | lgas222 | FLUENT | 4 | May 23, 2012 05:36 |
