Problem in Interpolating data command
Like Tree2Likes
  • 2 Post By Jim87
Old   July 14, 2013, 04:13
Default Problem in Interpolating data command
shubham
shubham208011 is on a distinguished road
I tried to read ip (interpolate data) file by using command file-->interpolate--> select file (ip.ip) in fluent but i get an error stating:
> Reading F:\E Drive\gambit&fluent\Pheumatic Conveying of Flyash\Case 3\New folder\ip.ip...
Variables for which data is found are following
pressure
mp-1
mp-2
epsilon-1
k-1
x-velocity-1
y-velocity-1
z-velocity-1
epsilon-2
k-2
x-velocity-2
y-velocity-2
z-velocity-2
Done.
Initializing values...
Error:
FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Error Object: #f
How could I resolve this problem??
Thanks & Regards
Shubham
shubham208011 is offline   Reply With Quote
Old   July 14, 2013, 06:10
blackmask will become famous soon enough
Perhaps run out of memory.
blackmask is offline   Reply With Quote
Old   July 14, 2013, 06:40
shubham
Thanks for reply..
Can be more specific as drive in which I am storing all fluent data has more than 80 Gb free space..
Old   July 15, 2013, 05:51
Stephan Langenberg
Jim87 is on a distinguished road
The interpolate data function need a characteristic structure, if one line is out of that there may be errors.
Example:
3 // Version of Fluent
3 // 3D-Geometry
800 // 800 interpolation points
4 // entries (pressure, temperature, phase 1, phase 2)
pressure
temperature
mp-1
mp-2
(0.0195 //now there are 7 blocks of 700 entries. First koordinats x,y,z and
0.0195 // then your values
0.0195
0.0195
0.0195
I am interpolating 120.000 points and it works. Running out of memory wsn't a problem for me (64 GB Ram)
Jim87 is offline   Reply With Quote
Old   July 15, 2013, 08:25
shubham
Can you please elaborate, I am not getting your point.
The steps i followed are exactly similar to those suggested in Fluent User Guide.
Step adpoted:
1.) Run the simulation for coarse mesh
2.) write interpolate file using command file-->interpolate-->write-->save (selected all variables)
3.) write boundary conditions using text command file/ write-bc
4.) read fine mesh using command file-->read-->mesh
5.) read boundary conditions using text command file/ read-bc (read same file generated at step 3)
6.) read interpolate file using command file-->interpolate-->read-->selected same file generated at step 2
Old   July 15, 2013, 08:52
Stephan Langenberg
You are firstsimulating in a coarse mesh and later you want to use a fine mesh, right?
- I did a similar operation a few month ago and it works good. Maybe your second and finer mesh doesn't fit to the data-file you are exporting.
Is it the same geometry in the first and the scond mesh?
You could check the mesh scaling and position, maybe this leads to an error.
- If you want torefine your mesh you can also do this in Fluent. The adapt funktion is able to refine a mesh without leaving the solver. Is this an option you could use?
Old   July 15, 2013, 09:18
shubham
Thanks Jim for replying
My two geometries are exactly same only difference is in size of mesh.
Yes I can use adapt function inbuilt in fluent for refinement of mesh.
Thanks..
[Commercial meshers] Problem converting fluent mesh vinz OpenFOAM Meshing & Mesh Conversion 28 October 12, 2015 07:37
UDF hook problem in command line mode. Benlong FLUENT 1 November 12, 2007 15:45
I fix a problem with DATA statement Soh Siemens 0 May 12, 2006 15:59
The problem of wall data getting when postprocessi WIlliams Siemens 4 March 6, 2006 11:14
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 18:27
