June 4, 2013, 11:51 |
Heat transfer through pipe wall
sheikh
Rep Power: 13 |
I am designing a gas water heater. i have modelled and meshed the whole structure. unfortunately the flue gases which are at a temprature of 750K do not seem to heat up the water through the wall. the temperature of the water remain at 303K at 2.5sec to 1min. Please help me in this regard kindly. what options in the wall must i select "on" so that heat is transfered through it to the water
thanks |
June 4, 2013, 15:58 |
Rep Power: 17 |
Your walls (between the flue gas and pipe and water) should be defined as coupled walls
Regards Luke |
June 4, 2013, 16:41 |
sheikh
Rep Power: 13 |
how can i define it as couple wall? in the fluent on the option of wall comes?
June 4, 2013, 17:59 |
Rep Power: 17 |
Yes it is an option in wall BC screen, i think under the Temperature tab
Regards Luke |
June 5, 2013, 04:15 |
sheikh
Rep Power: 13 |
unfortunately i can not find such option. the options available to me are as follow in the picture shown.kindly please help
Syntax errors with Thread Types and Wall Heat Transfer calculation | jcespada | Fluent UDF and Scheme Programming | 2 | March 16, 2012 03:23 |
Heat transfer BC at wall- why need wall thickness? | Julie | FLUENT | 7 | February 3, 2012 22:41 |
Pipe Flow Heat Transfer | Saima | CFX | 5 | January 30, 2011 17:41 |
Heat Transfer in a pipe flow(hot air) | Saima | Main CFD Forum | 0 | January 17, 2011 08:08 |
Wall heat transfer coefficient (HTC) problem | Mohamed khamis | CFX | 1 | January 16, 2010 00:12 |
