number of iterations to converge solution in Fluent as Ansys Workbench output param
Like Tree2Likes
  • 1 Post By nnvoro
  • 1 Post By oj.bulmer
Old   May 1, 2013, 14:52
Default number of iterations to converge solution in Fluent as Ansys Workbench output param
nnvoro is on a distinguished road
I'm solving blood flow in Ansys 14.5 Fluent in batch mode. In Fluent I fix the maximum number of iterations but while running different cases in batch mode I can't figure out if my solution converged or just the number of iterations exceeded the maximum number of iterations.
Does anybody knows how can I set this number as output parameter in Ansys Workbench?
Thank you!
nnvoro
nnvoro is offline   Reply With Quote
Old   May 1, 2013, 15:14
OJ
oj.bulmer will become famous soon enough
Do you mean, you want to just see the progress of the FLUENT iterations? There is a setting in options to enable the monitoring of FLUENT residuals. Once enable, residuals of any FLUENT simulation running in Workbench can be seen by right click on it.
OJ
oj.bulmer is offline   Reply With Quote
Old   May 1, 2013, 16:01
OJ
OJ, can I see them after the calculation fro one design point is finished and another design point is calculated? I want to be able to review the number of iterations for each point after calculation for all of the points is finished.
Rik102 likes this.
Old   May 1, 2013, 16:05
OJ
To be honest, I don't often run the FLUENT in batch mode. Why don't you give a shot to it as I suggested and update here if it worked for you?
OJ
nnvoro likes this.
Old   May 2, 2013, 02:18
Paritosh Vasava
vasava will become famous soon enough
There is an option in workbench called 'parameter'. I know that you could study the effect of geometry (e.g. effect of length or diameter of a pipe on the flow) or flow model parameters (e.g. effect of inlet pressure or velocity) without actually setting up multiple cases with different parameters. But I am not sure if it will work for convergence criteria.
I think you need to select your own criteria to decide if the solution has converged and try to parameterize that.
vasava is offline   Reply With Quote
Sudden jump in Courant number NJG OpenFOAM Running, Solving & CFD 7 May 15, 2014 14:52
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 09:35
Extremely slow simulation with interDyMFoam jrrygg OpenFOAM Running, Solving & CFD 9 April 23, 2013 11:14
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
Error while running rhoPisoFoam.. nileshjrane OpenFOAM Running, Solving & CFD 8 August 26, 2010 13:50
