April 26, 2013, 04:24 |
Heat Transfer convergence problem
Rep Power: 17 |
Hi everyone,
I want to model heat transfer through a wall in Fluent. I have several layers of material, including some shell conduction. I set freestream T 293K "inside" and 273 K "outside". Now, to check if my calculation is converged, I observe Total Surface Heat flux on faces "in" and "out", and I would expect that the sum of these fluxes would tend to 0. It does indeed tend to it, but very very very slowly and I still have something like 7% error between flux in and flux out, which is I think too much.... I first had a under-relaxation factor quite low, but then I progressively raised it up to 0.99 now, and even if it does help "getting there" faster, it still appears that it will never completely converge (in fact relaxation factor helps just a very little bit). I tried first 2nd order upwind scheme, now I tried QUICK, it doesn't change anything. Residuals are fine. I have 2 different geometries, the problem occurs in both except that in my second geometry, the fluxes are higher, so the error is much less in %. (but it's the same magnitude of error in Watts). Does anybody have an idea on what could be the problem and how to solve it ? Thanks a lot ! |
April 26, 2013, 07:29 |
#2 | |
Rep Power: 13 |
please i want some responses |
inverse heat transfer problem | siva0182 | FLUENT | 6 | February 22, 2019 07:00 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
Inverse and Transient Heat Transfer Problem on commercial software: is it possible? | rogbrito | CFX | 1 | January 29, 2012 18:48 |
regarding B.C. of Heat transfer problem | Manoj Padmakarrao Raut | Siemens | 0 | March 17, 2005 01:01 |
Heat transfer problem | Brian | CFX | 0 | September 13, 2004 02:19 |
