Condensing Steam Analysis - What Model Should I Use?? |
April 22, 2013, 07:40 |
Rep Power: 15 |
Hi all,
My analysis includes two-phase steam flow in a pipe (with 15% steam mass fraction, or 2% volume fraction). At a certain location, cold water is injected into the pipe, so that the steam condenses. The aim of this analysis is to determine the exact location (after the cold water injection) at which all of the steam has condensed into water. Fluent has a built-in Wet Steam model (available with the density based solver), but it has a limitation of 20% steam mass fraction (according to the Users Guide), while my analysis requires a full condensing of the steam. Another option is to use a regular multiphase model with pressure based solver (I suppose the Eulerian is the most suitable?), but it requires creating complicated UDF's that model the mass and heat transfer from the vapor to the water. (1) What would you suggest in such a case? What model is the most suitable? (2) Can I use the Wet Steam model, disregarding the 20% mass fraction limit? (3) Are there any tutorials for steam condensing problems? Thanks a lot in advance!! |
April 22, 2013, 23:21 |
董生
I think you can use UDF to model the phase changing. You can find the UDF file on the Internet
April 24, 2013, 07:48 |
Rep Power: 15 |
Thanks dlrobin!
Can you please refer me to a good condensation UDF? |
April 25, 2013, 14:50 |
mehrdad
Rep Power: 15 |
hi i'm working on a similar case and i use mixture model. i used the model evaporation-condensation model in fluent but you also need a source term for energy equation but when i run the case with energy source term i cant converge it.i also wrote a udf for both mass transfer and energy source term but when i run it fluent says :
Error: Divergence detected in AMG solver: pressure correction i haven't anyone help me to fix this .if you want give me your email and i send this udf to you. |
February 2, 2015, 22:37 |
#5 | |
Kulasekharan
Hi Mehr,
I am working on steam generation and condensation for a solar still. Can you please share the UDF to me too. pls send the UDF to cfdsekar@gmail.com Thanks for your help. If i get any breakthrough, will share with you. Thanks Kula Quote:
November 28, 2016, 23:12 |
Steam Condensation ANSYS-fluent
Atif
Anyone got UDF file for steam condensation ?
cfd, condensing, fluent, steam, water |
error message | cuteapathy | CFX | 14 | March 20, 2012 07:45 |
Turbulence model pressure drop analysis | Nail | Main CFD Forum | 2 | March 21, 2011 19:12 |
Steam Diffusion Coefficient - Mixture model | Graham Brett | FLUENT | 0 | February 21, 2008 18:32 |
DRAG ANALYSIS ON 3D FLIGHT MODEL | vidhyasagar s | FLUENT | 0 | February 14, 2008 11:52 |
Different fluid model in single analysis | rajinikanth | FLUENT | 0 | February 12, 2007 07:48 |
