April 19, 2013, 12:12 |
Define another cell zone
sheikh
Rep Power: 13 |
I am modelling a gas water heater for my FYP so i have do analysis on ansys 14.0. I have constructed the body and even the mesh, but unfortunately when i go into fluent it only give me a single option of cell zone conditions where as my geometry is of 2 concentric pipes, one with flue gases and other of water. Please help me in this regard. how can i separate the cell zone and define 2 different zones, one for each tubes?
April 19, 2013, 15:56 |
Separate cell zones
Bill Wangard
Easy way to separate one cell zone into two:
1. Adapt->Region 2. Define a rectangular block that marks the inner cells of your zone 3. Mark the cells, but do NOT adapt. 4. Mesh-> Separate-> Cells... 5. Separate based on adaption register. Pick the cell zone and register that you just created. 6. Click separate. Now you will have two separate cell zones. Note that additional face zones will be created. Interiors that mark the new boundary, and other zones that span the two zones will be separated. To identify the zones, 1. Surface-> Zones... 2. In the left panel, seleect the newly created cell zone (and perhaps the other one, too). For each one, click create surface. then in the Display mesh panel, you should be able to see the cell zones in the list of surfaces. Hope this helps, Regards, Bill Wangard Engrana LLC |
April 19, 2013, 15:58 |
Ghazlani M. Ali
Rep Power: 29 |
separation can be done in fluent , but it will never be as precise as in the meshing software. how you used icem cfd for that ? if so you need to define too bodies. have a look at the link a attached in my signature. it's a small book where i explain the principle of having multiple bodies while meshing...
April 20, 2013, 07:40 |
sheikh
Rep Power: 13 |
thanks alot. i have tried your method and it seems to work a bit. can you please tell me more detail about defining two zones in meshing? i have not really used icem cfd as such..
thank you |
April 20, 2013, 18:32 |
Rep Power: 13 |
I've never used ICEM, but I do surface tria meshing in HyperMesh before doing volume meshing in ANSYS Fluent Meshing Mode. Generally speaking you should place the mesh sections you want as separate zones in separate components (the actual term may vary) during the meshing process itself.
April 21, 2013, 09:24 |
sheikh
Rep Power: 13 |
i have added two extrudes as frozen representing two bodies but when i open fluent they have single cell zone meaning they have 1 fluid flowing through them.. how can i separate components or zones at meshing stage?
February 16, 2015, 07:20 |
Mayur Bhandari
I cannot select the region by clicking mouse.
"Click on diagonal points defining the hex in the graphics window with the MOUSE-PROBE mouse button" This window is appeared? |
November 23, 2015, 10:57 |
#8 | |
Ankit Tiwari
If you are using ANSYS Meshing and want to export different mesh regions as different cell zones, I suggest you do the following, group similar cell zones , say fluid zones under a new part in ANSYS DM by selecting the desired objects, right clicking in the object tree and clicking on "form a new part" option. Repeat the above steps for all the cell zones |
FLUENT porous zone inputs | eishinsnsayshin | FLUENT | 19 | April 17, 2020 04:40 |
[Other] How do you define a cell zone or region for porous? | bigbang | OpenFOAM Meshing & Mesh Conversion | 6 | March 18, 2016 17:42 |
[GAMBIT] periodic faces not matching | Aadhavan | ANSYS Meshing & Geometry | 6 | August 31, 2013 11:25 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 10:52 |
REAL GAS UDF | brian | FLUENT | 6 | September 11, 2006 08:23 |
