Full MultiGrid setting
Like Tree1Likes
  • 1 Post By CDollarsign
Old   April 17, 2013, 08:40
Default Full MultiGrid setting
HA11 is on a distinguished road
I'm trying to set FMG inputs in fluent command console, and it gives me invalid command error.
> solve/initialization/set-fmg-initialization
invalid command [set-fmg-initialization]
do you know why?
Regards,
HA11 is offline   Reply With Quote
Old   April 17, 2013, 11:28
Colin Fiola
CDollarsign is on a distinguished road
I think you need a slash between set and fmg-initialization.
solve/initialization/set/fmg-initialization
HA11 likes this.
CDollarsign is offline   Reply With Quote
Old   April 17, 2013, 22:01
Smile
Thanks,
The command is right, but the problem was from solution initialization.
I restart the fluent and in solution initialization, by redoing the "initialization"...the command the same as I mentioned was working...
Old   April 28, 2014, 14:02
Sheng
micro11sl is on a distinguished road
Originally Posted by HA11 View Post
Thanks,
I think you need an exsiting solution to make that fmg initialisation work. Apart from that, using fmg initialisation sometimes cannot drop residual more than 3 orders in my 3D external flow cases. So be careful of it, I find hybrid initialisation is somewhat good enough.
micro11sl is offline   Reply With Quote
Old   October 20, 2016, 22:53
Mahdi
mahbood is on a distinguished road
Hi folks,
Same problem for me on Fluent 17.1,
mahbood is offline   Reply With Quote
Old   May 3, 2017, 09:26
kingjewel1 is on a distinguished road
I type:
sol ini hyb
sol ini fmg
Tested on 17.1
As a caveat- It depends on your mesh and sometimes causes the whole thing to crash. Secondly it doesn't work with a transient solver. Anyone know why it can't handle a transient solver setting?
kingjewel1 is offline   Reply With Quote
Old   May 3, 2017, 10:18
Wink ANSyn FLUENT
Joshua keftin Amuga
Keftin is on a distinguished road
Send a message via Yahoo to Keftin
Good day, I am a masters student from ABU zaria in Nigeria, I want to perform simulation for a flow field of a harmonic pattern Diffuser argumented wind turbine. I want to know if someone can teach me how to simulate the flow fields. Thank you
+2347010398094
Keftin is offline   Reply With Quote
Residual level setting of Fluent lhlh ANSYS 2 November 17, 2012 22:35
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 22:58
multigrid sureshkumar Main CFD Forum 0 June 9, 2006 02:20
Warning 097- AB Siemens 6 November 15, 2004 05:41
Multigrid applied to k-e models Paulo Zandonade Main CFD Forum 9 May 24, 1999 09:10
