Convergence problem with fluent
Like Tree2Likes
  • 1 Post By blackmask
  • 1 Post By oj.bulmer
Old   April 1, 2013, 07:07
Exclamation Convergence problem with fluent
Hakim Mkacher
kiurigan is on a distinguished road
Hi every one.
I'm dealing with a Rayleigh-Bénard problem on Fluent. The problem is that the solution refuse to converge even after thousands of iterations here the screen capture of the residuals:
thank for all
kiurigan is offline   Reply With Quote
Old   April 1, 2013, 10:44
blackmask will become famous soon enough
The convergence criteria is problem specific. It seems that your solution has already been converged.
kiurigan likes this.
blackmask is offline   Reply With Quote
Old   April 2, 2013, 08:53
Hakim Mkacher
Thanks for reply.
Actually I'm dealing with a translational periodic flow with fixed pressure gradient. If you have any tips to judge the accuracy of convergence I will be so grateful.
Old   April 2, 2013, 09:15
I really do not remember what my college used to judge convergence when he simulated a similar problem. I think the convergence of mass flow rate might be a good indicator.
Old   April 3, 2013, 12:43
OJ
oj.bulmer will become famous soon enough
Try creating several monitors of properties (pressure/velocity/temperature etc) that are important to your physics. Monitors can be points/surface average monitors etc. If the problem is steady (as it appears) the monitors should be flat.
You can also monitor volume averaged mass imbalance, it should small.
OJ
oj.bulmer is offline   Reply With Quote
convergence, fluent, problem, residuals
Convergence Centurion2011 FLUENT 48 June 15, 2022 00:29
Fluent - license problem. Marcin FLUENT 3 April 13, 2018 17:33
Fluent parallel license problem brothershuai Main CFD Forum 0 July 1, 2009 16:41
Standard convergence limit in FLUENT 6.1 Henrik Ström FLUENT 3 December 20, 2005 09:48
convergence problem limseokmin FLUENT 3 November 14, 2004 13:43
