Fluent results at specific point
Like Tree2Likes
  • 1 Post By chaosh
  • 1 Post By chaosh
Old   March 5, 2013, 15:31
Unhappy Fluent results at specific point
jipaz is on a distinguished road
Hi all, I'm doing an FCC riser gas-solids flow simulation using Ansys Fluent 12, and I need to get results at specific height of 3.9 m from the riser bottom. Somebody knows how to define this task at Fluent? Any help is very welcome.
jipaz is offline   Reply With Quote
Old   March 5, 2013, 15:50
sp
chaosh is on a distinguished road
I am assuming you want area averaged data at some given point. You need to create a surface at that elevation. Basically, if you know the coordinates, you need to create a 'bounded' plane. Look at fluent tutorials for creating planes. You will work from the 'surface' option in the top toolbar.
An easier way to do this is to use the 'sweep surface' option when you are in the graphics and animations menu. Basically after your solution is initialized/complete you need to display the mesh and then use the sweep surface slider in the direction you want to sweep until you get where you want to be.
For example, if your location is in the z direction you need to set x=0, y=0 and z=1, hit compute, and then use the slider. You can create a face this way if your geometry allows it.
If you want one POINT..after the above step you can click on that face, and create a point from the surface menu.
Good luck
jipaz likes this.
chaosh is offline   Reply With Quote
Old   March 5, 2013, 16:09
Thanks Chaosh, but I forgot say that I'm working with a 2D simulation, and I suppose you are talking about a 3D simulation, could you tell me how to do the same in 2D?
Old   March 5, 2013, 17:44
sp
2-D is very straightforward - you need to create a line instead of a face. Go to the 'surface' menu and choose line. You just need to display the mesh and pick the location you need (Fluent tutorials would help a lot), create a line.
To locate where your point should be you can right click on the mesh till you get close to where you want. Go to "Display > mouse buttons>" and change from short description to long description in the drop down menu. Now when you right click on the mesh your coordinates will be displayed in SI units.
Another way is to plot contours of your mesh (Contours - mesh - x coordinate, and then y coordinate) to figure out an approximate place you can click with your mouse.
Also, in case you didn't know this, you will need to go to results>reports and then pick 'area weighted average' or whatever else you want of the quantity in question, and compute. This will display the value of the quantity on your screen.
jipaz likes this.
I hope you can point out problems in my FLUENT solution tp9180188 FLUENT 2 March 15, 2012 12:40
FLUENT results to ANSYS Jin Yan FLUENT 2 April 28, 2011 12:22
results in a specific point rcerdeira FLUENT 1 February 21, 2011 15:27
Exporting Fluent results as 4D images in an interactive window Luca95314 ANSYS 0 October 11, 2010 18:16
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
