Bingham fluid parameters
Like Tree2Likes
  • 1 Post By Stejohn
  • 1 Post By Stejohn
Old   February 28, 2013, 17:45
Default Bingham fluid parameters
Jan Stejskal
Stejohn is on a distinguished road
Greetings!
I´m trying to simulate laminar flow of Bingham fluid in Fluent 12.1 by using Herschel - Bulkley model. I´ve got constants which are needed to define Bingham fluids parameters...binghams apparent viscosity and value of yield shear stress from experiment.
But there is problem with "critical shear rate" column...I have no idea what should i type into this. Is there anyone whou could advice me?
Thanks for every proposal!
Abhi.shek likes this.
Stejohn is offline   Reply With Quote
Old   March 1, 2013, 16:43
Jan Stejskal
No proposals from local experts?
Old   April 18, 2013, 00:42
bruce
brucecumt is on a distinguished road
Originally Posted by Stejohn View Post
Greetings!
I get stuck on this problem as well. Does anyone have any idea about this problem. How to determine the "critical shear rate" in Bingham or Herschel-Bulkley model in ANSYSFLUENT? Anyhelp will be appreciated!
brucecumt is offline   Reply With Quote
Old   April 18, 2013, 15:26
Jan Stejskal
I´ve figured it out. Bingham fluid behaves like "solid" mass in area under critical shear rate. You should insert number near to zero to this column. I usualy insert 0,01 or 0,001 and it works pretty well.
liliana likes this.
Old   April 19, 2013, 03:06
bruce
Thank you mate. I found if the critical shear rate you input is too small, some numerical instability will occur, especially when the flow speed is very low. Anyway, I think this parameter is almost impossible to get from the lab test. The only way is to try different number and see if the simulation results have a good agreement with pratice. Keep changing it until it yields reasonable result.
apparent viscosity, bingham
How to get Pro/E Parameters to Show Up Trues CFX 4 September 17, 2012 21:26
Questions of fluid pairs fjalil CFX 1 June 10, 2009 18:36
Fluid pairs fjalil Main CFD Forum 0 June 10, 2009 14:47
My Revised "Time Vs Energy" Article For Review Abhi Main CFD Forum 2 July 9, 2002 10:08
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
