February 25, 2013, 12:05 |
Fluent Adjoint Solver?
Malik
Rep Power: 13 |
Hello Everyone!
Hope you are all doing good. I needed help regarding the functionalities in Ansys Fluent Adjoint Solver. I wanted to ask if any of you had any experience with the Adjoint Solver in Fluent? As for my final year project I am using lift constrained drag minimization approach for a formula one front wing and I have tried to find some material on how best to use adjoint solver inorder to get a converged solution. I am having trouble in settings of controls section in the adjoint solver module inside fluent as no information can be found for best setting for turbulence modelling I can't seem to get the right combination of settings and as a result my solution is diverging. The solver seems to converge perfectly alright for the conventional flow solver but its just the adjoint solver convergence I am having issues with. Any details on how to set the settings in adjoint flow solver for converged solution will be much appreciated. Thank You. Have a nice day. Best Regards, Ahmed. |
February 25, 2013, 13:06 |
#2 | |
Sheng
Rep Power: 15 |
As far as I know, the adjoint Fluent solver only allows you using k-epsilon with standard wall function turbulence model. A general step may be: run your case with the turbulence model you're preferred for accuracy, run adjoint solver with the k-epsilon with standard wall function turbulence model, after the done the mesh morpher, rerun the new case with your preferred turbulence model. In this way, the results of the adjoint solver is regarded as "guiding solutions". I am not using the adjoint solver actually, so I can't guarantee my way can solve your problem. I am personally interested with it and I have attended an ANSYS Fluent webinar session talking about how to use the adjoint solver. Please check if you can have a customer account, so you can have access to those material as well. You can apply for a student account if you're eligible. Regards, Sheng Quote:
February 25, 2013, 13:10 |
Reply: Fluent Adjoint Solver!
Malik
Rep Power: 13 |
Thanks for your reply. Well I have attended the two webinars on the Adjoint Solver so far and I have read all the material available on Fluent Adjoint Solver. I know the steps that you have mentioned but I need some help in the control settings of Adjoint Solver where the stabilization schemes and preconditioning are set? Because with my current settings the solution tends to diverge? Any help on that will be much appreciated. Thanks again.
February 28, 2013, 05:19 |
#4 | |
Sheng
Rep Power: 15 |
Sorry to reply late. In my limited experience, I managed to converge by "uncheck" the "apply preconditioning" for my low Reynolds number aerofoil case. I find I can't replot the residual history, so I only upload the settings on the panel. Regards, Sheng Quote:
February 28, 2013, 08:44 |
Malik
Rep Power: 13 |
Thanks a lot for your reply. As a test case I also did a 2D optimisation of NACA0012 using the Fluent Adjoint Solver and it did converge by turning off the preconditioning option. But I am doing optimisation of front wing of a formula one car with wheel aswell and that makes the mesh size pretty large with separation aswell at the trailing edge of the flaps and when I turned off the preconditioning option it diverged straight away as specifying the values of artificial compressibility and courant numbers is absiolutely necessary for stable operation of the adjoint solver and using low values of Artificial Compressibility(between 0-1) and Courant Number(0.1-2.5) aids in stabilizing the convergence.
Do you know anyone who might know how to set the right values for adjoint controls inorder to get a converged solution? As the only problem I am facing is adjoint convergence. Thanks a lot. |
March 14, 2014, 05:03 |
adj solver diverges
#6 | |
Ali Yıldırım
Rep Power: 13 |
Dude can I ask to share your NACA0012 profile adjoint solution and control settings since I am working on it but solution diverges somehow. I am stuck!
May 1, 2014, 10:48 |
caphfa
Hello people!
Maybe somebody find out the way to overcome divergence problems in adjoint solution? It seems I have tried almost all possible variants of adjoint solver settings and also I tried different “high quality” grids, but results are still far from converged solution. So, if it is impossible to obtain fully converged adjoint solution, can I use calculated gradient for optimization purposes? If somebody has similar experience I’ll be very thankful for any advice. Thanks |
September 5, 2014, 13:35 |
#8 | |
Francisco Palacios
Rep Power: 15 |
Cheers, |
January 30, 2015, 08:33 |
#9 |
Rep Power: 13 |
In order to get good convergence with the Adjoint you have to check the following steps:
January 30, 2015, 08:34 |
#10 |
Rep Power: 13 |
last point: use R16!
July 7, 2015, 17:36 |
#11 |
Ehsan Asgari
Rep Power: 18 |
Not quite a solution, but lowering mesh number can possibly lead to convergence!
July 9, 2015, 18:48 |
#12 |
Rep Power: 14 |
R16 does not help. Still not converging after 300 iterations and doing all of the above settings
July 10, 2015, 08:53 |
#13 |
Ehsan Asgari
Rep Power: 18 |
Dears,
I just want to share my experience of using Fluent Adjoint solver! In one of the cases, I had an airfoil in low AOA in subsonic flow regime. My goal was to optimize that airfoil in terms of L/D (lift to drag ratio). In this case, Adjoint solver was very helpful and after some iterations, L/D was increased appreciately. In another case, I wanted to optimize the same airfoil in a high near stall AOA. I had a constraint on the lower surface of airfoil and was not allowed to modify its shape, so I was only permitted to make modifications on the upper surface. The premium goal was optimizing the airfoil by delaying separation point as much as possible, while retaining the L/D ratio. In this case, Adjoint solver did not perform as expected. Initially, I used a standard structured fine mesh which I used for static airfoil at different AOAs. I tried to use the same mesh for Adjoint optimization, but I could not manage to get a converged adjoint solution, no matter how much I played with controls and schemes! Then, I decided to use a coarser mesh with fewer cells on the upper surface. Well, this time it converged without any trouble! But the problem has just begun! I could get an optimized solution with higher L/D of about 1 or 2 units, I let the optimization iterate for more than 250 times (250 different shapes!) and the separation point was also delayed toward the trailing-edge. I was quite satisfied with the result, but when I examined the mesh quality rear the airfoil, it was disaster! The problem is that when Adjoint solver tries to optimize the airfoil shape, the mesh over the airfoil is also taken into account. In other words, Adjoint manipulates both the mesh and geometry (not geometry alone!) to optimize the solution, and it is a disaster!! In my case for example, it ruined the mesh orthogonality to gain higher lift and delay the separation. I tried to apply the former standard mesh to the optimized shape, and when I run it in the fluent, that was the real disappointment, the result was ONLY slightly better than the base geometry. L/D was much lower than that which Adjoint gave me using the deformed mesh!!! Finally, I gave up using adjoint for this case and used some other primitive methods to achieve my goal!!! I hope it could help some people who are dealing with Fluent Adjoint solver!! Last edited by syavash; July 10, 2015 at 12:11. |
July 11, 2015, 11:03 |
#14 | |
Ehsan Asgari
Rep Power: 18 |
But examining the mesh of the 2nd optimization VISUALLY might not be a perfect way to judge the Adjoint solver. I suggest to let it proceed further, for instance 50 cycles. Then go to the mesh display and examine the mesh deformation once again. Bests, Syavash |
July 11, 2015, 19:42 |
#15 |
Rep Power: 14 |
I got it to work now.
But how can I export the modified mesh? |
July 21, 2015, 02:13 |
#16 |
Rep Power: 14 |
got it sorted somehow, its still e bit erractic. Sometimes it updates the mesh, sometimes not.
But the predicted values are way more optimistic than the results. In my reducing elbow I found a few tens Pa. The Bernoulli part is about 5500Pa, so its no surprise it hoped to skim off a few 100Pa, but initially I only got 6100Pa. |
September 28, 2018, 09:11 |
#17 |
urosgrivc
Rep Power: 12 |
be sure to make very small changes to the geometry I usually use 2% improvement per optimisation loop which is then automated with journal files so a lot of loops and small steps is done.
If you make big changes like 10% a lot can go wrong. Convergence is relatively good on the k-epsilon model but for k-omega it diverges in my case. SST is not supported |
fluent, fuent adjoint solver, turbulence modelling |
Fluent IcePak - AMG Solver | Russ | FLUENT | 2 | December 31, 2018 10:57 |
Multiphase modelling using Fluent VOF: Solver settings | akash | FLUENT | 0 | February 22, 2013 07:29 |
Compressible flow solver in Fluent | jwillie2000 | FLUENT | 4 | May 25, 2012 10:58 |
help required in using six dof solver in fluent | Shah | FLUENT | 1 | February 25, 2006 12:31 |
Viscous adjoint solver | Steve | Main CFD Forum | 1 | March 7, 2002 06:05 |
