Multiphase+Multicomponent mass fractions
Like Tree3Likes
  • 1 Post By beer
  • 1 Post By beer
  • 1 Post By beer
Old   February 24, 2013, 09:57
Question Multiphase+Multicomponent mass fractions
NPat is on a distinguished road
I'm a new user of ANSYS FLUENT...
I'm trying to model a steady-state multiphase+multicomponent problem in ANSYS FLUENT 14.0. There is phase change in the model, so the composition of each phase changes along the domain. I have a question about the boundary conditions for mass fractions...
The inlet mass fractions are easy to understand and the inputs are straightforward... but, what about the mass fractions at the outlet?
FLUENT ask me to input mass fractions for each species in both phases at the outlet, but that is in fact what I'd expect it could calculate for me... Anyone has some ideia of how could I treat this problem? What could I input in the outlet BCs if I have no ideia about the expected value...
Best Regards.
NPat is offline   Reply With Quote
Old   February 24, 2013, 12:43
beer is on a distinguished road
Hi NPat
the mass fraction condition you set at the outlet boundary is the backflow mass fraction. If you have no backflow, you have nothing to worry about.
Greetings
NPat likes this.
beer is offline   Reply With Quote
Old   February 24, 2013, 16:02
Thank you! Could I assure that there is no backflow in my problem setting up a pressure outlet boundary condition to zero?
Regards.
Old   February 24, 2013, 16:22
I don`t know what you mean with zero, zero pressure or zero mass fraction? You can't assure that there is noch backflow on a pressure oulet. One oppurtunity is, you could use a mass or velocity outlet and a pressure inlet instead. Or, and that is the best solution in my opinion, you could extend your mesh to a point where you can be sure not to generate backflow or it does't matter anymore. If you just don't want to have a backflow of one species you can set this species to zero, which is easy but unfortunatly not physical.
Greetings
NPat likes this.
Old   February 24, 2013, 17:01
I meant zero (gauge) pressure at the outlet as a condition to avoid backflow. Thank you for your reply, Marcus.
Old   February 24, 2013, 18:04
You're welcome
NPat likes this.
Old   February 25, 2013, 07:40
I have some additional questions about backflow and outlet mass fractions...
FLUENT tells me that I have backflow in my calculation when it displays the message "reversed flow at the outlet", right? So, let's say I can prevent backflow extending my domain and so on... in this case doesn't matter which value the species mass fractions are assigned... so could I put zero mass fractions for all species mass fractions (assuming no backflow)?
Best Regards.
fluent 14, multicomponent
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Difference of multicomponent and multiphase homogenous flows Luk_Fiz CFX 11 April 4, 2013 06:29
multicomponent flow-component mass fraction at inlet mengyue1 CFX 0 January 5, 2012 00:49
Multiphase Multicomponent mass transfer -Initial condition pannsave CFX 10 February 9, 2011 02:12
Mass conservation problem in mixing tank multiphase simulation rockewan FLUENT 0 April 6, 2010 13:34
