February 5, 2013, 17:07 |
Imep
William
Rep Power: 13 |
I am modeling combustion in a heavy duty diesel engine with some set parameters to include in the setup. Where would I implement IMEP (indicated mean effective pressure) in the simulation setup? I have a value of 3.9 bars to set.
February 25, 2013, 08:51 |
Cristiano
Rep Power: 13 |
i'm not sure, but i Think you can insert this value in "solution inizialization". Tell me if it works |
February 25, 2013, 10:31 |
William
Rep Power: 13 |
Thanks for your reply. I received done outside help and found that it is a calculated value.
February 25, 2013, 17:11 |
Rep Power: 13 |
wmoote how did you modelled internal combustion engine?would you send me informations in fluent please?
February 27, 2013, 11:06 |
Is this any help to answering your question cemilbercin?
William
Rep Power: 13 |
Crank Shaft Speed(rpm): 1200
Starting Crank Angle: 195 (i.e. 165 degree before top dead center, which is set at 360) Crank Period (deg): 360 Crank Angle Step Size (deg): 0.2 Piston Stroke(m): 0.1524 Connecting Rod Length(m): 0.3048 Injector position: x: -1.5e-3 m radius: 1.5e-3 m Injection angle: 152 degree start of injection: 5 degree before top dead center during of injection: 10 degree mass of injection: 7.65e-6 kg temperature: 368 K cone angle: 7.5 degree mean droplet diameter: 1.96e-4 m injection velocity: 200 m/s Initial conditions: temperature=320.15K pressure: 1.92e5Pa - 101325pa (to get gauge pressure) oxygen (O2) mass fraction: 0.233 Boundary conditions: Piston temperature: 500 K Cylinder wall temperature: 420 K Cylinder head temperature: 470 K |
February 27, 2013, 14:06 |
Rep Power: 13 |
thank you very much brother...are you student or engineer?ı have to improve my fluent ability so would you send me any fluent applications with picture or training videos?
February 28, 2013, 05:09 |
Cristiano
Rep Power: 13 |
On https://support.ansys.com you can find everything
February 28, 2013, 17:19 |
Rep Power: 13 |
thank you very much brother wmoore16 and fluent 87...but how can I enroll or register in this site? https://support.ansys.com ı can not go in this forums...could you help me please?
ı should find fluent applications for booting my knowledges.thank you for yours all help. |
March 1, 2013, 05:56 |
#9 |
Cristiano
Rep Power: 13 |
if you are student you can register yourself on
https://support.ansys.com/portal/sit...plate.REGISTER also, if you are not student, apply on https://support.ansys.com/portal/sit...late.REGISTER/ Anyway you need the customer code that you can find Ansys License Invoice (yours o your University). |
effective pressure, imep, pressure |
