VOF with melting of Phase change materials
Like Tree2Likes
  • 1 Post By vig
  • 1 Post By thermal energy
Old   January 23, 2013, 14:05
Talking VOF with melting of Phase change materials
mahmood
sakil2k3 is on a distinguished road
Dear all,
I m modeling a phase change problem with VOF and solidification. The problem description is a biker containing PCM and air. When i simulate the melting is only from the down and wall side. No melting is occurred due to upper air surface. I m uning pressure outlet for upper boundary condition.
can any one help??
sakil2k3 is offline   Reply With Quote
Old   January 24, 2013, 07:36
vig
anonymous
vig is on a distinguished road
Melting would initiate from the points where the temperature is above the melting temperature which could be the case near the walls. Pressure outlet boundary has the input for backflow temperature, it means melting of the top layer depends on temperature being initialized in the air phase.
thermal energy likes this.
vig is offline   Reply With Quote
Old   March 15, 2014, 07:53
thermal energy is on a distinguished road
Hello dear friends,
I try to simulate melting process using VOF model. Pcm is solid phase initialy. Upper part of the solid there is air. They do not mix eachother. the rectangular box is %85 full with solid pcm, %15 air
Natural convection is active. My primary phase air, secondary phase is pcm (phase change material). I have some questions to be sure about my model.
Initial condition of Wholesystem temperature is 293K, but air temp is 300K. how to set air temp ? from materials -referance temperature?
For cell zone condition, all cell zone (air, pcm, fin ) show mixture. Also for example, if I change pcm to phase2, all of cell zone change to phase 2 . is it ok or not
Only for secondary phase (pcm), I patch within fluent by adapt-region-mark then patch. Ok? Value of volume fraction should be 1 or 0 while patching?? I am confused. Initialy pcm is solid. the rectangular box is %85 full with solid pcm. %15 air
For initial values phase-2 volume fraction is 0 or 0.85. Ok?
I did some iteration for a short time to check model. For results, in graphics-countors I can not see total temperature for phase 1 and 2 only entalphy values I see for phase1 and 2.
Also countors of solidification/melting it shows only mixture. Mixture shows what?
Any interaction should I use like surface tension etc.
Thanks for your help. ı am really in stuck. good work friends.
Ibtissam likes this.
thermal energy is offline   Reply With Quote
Old   March 17, 2015, 16:26
Default help
Mohamed
B.Hamada is on a distinguished road
salam
I have a same problem, can you help me with a model, i have a pcm in an closure in aluminium without air, but in VOF there are two phase but i have one.
B.Hamada is offline   Reply With Quote
solidification/melting, vof
melting + vof modeeling for PCM in air taw FLUENT 2 August 24, 2018 01:21
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 17:12
simulation of phase change material melting rosol FLUENT 4 December 8, 2015 08:56
Help with phase change materials rosol FLUENT 0 December 22, 2007 13:15
help needed about phase change Yanhu Guo Main CFD Forum 4 January 24, 2001 00:16
