Can Fluent measure the mass flow of water/sand mixture? |
January 21, 2013, 13:26 |
Osamah Ali Al-Hashimi
Rep Power: 14 |
I have a hydrocyclone model supplied by water+sand mixture; a percentage of sand should be separated from water. Can fluent give me information about this percentage? How much sand (kg/sec) will goes from the top outlet and how much will goes to the down outlet? It is working with water as follows: Inlet = 0.84767848 kg/s Top_Outlet= -0.71924299 kg/s Down_Outlet= -0.12842806 kg/s But for Sand: Inlet = 0.041 kg/s Top_Outlet= ??? kg/s Down_Outlet= ??? kg/s 383px-Hydrocyclone.png My Geo.jpg |
January 25, 2013, 05:48 |
Rep Power: 14 |
Any response please....
January 28, 2013, 12:01 |
NormalVector
Rep Power: 15 |
Can't you do a flux report to get the total mass flow and then use a surface integral report to get the mass fraction of your sand?
January 29, 2013, 13:15 |
Rep Power: 14 |
Many Thanks for your reply, but could you please give me more clarification, what to select from the surface integral tap?
11.jpg I have a DPM not Mixture or Eulerian. Again Thank you very much friend. Last edited by Al-Hashimi; January 29, 2013 at 14:59. |
January 30, 2013, 15:05 |
NormalVector
Rep Power: 15 |
Your report type could be something like "Area Weighted Average" and then your field variable could be "Mass Fraction of ________". Does that get you what you want?
January 30, 2013, 19:47 |
NormalVector
Rep Power: 15 |
Sure there is. The report type is "Area Weighted Average", the field variable is "Species..." and then you choose "Mass fraction of _____". Of course that's if you have enable species transport. If you haven't, maybe I misread your question but it seems you should be keeping track of multiple species. I'm not sure if it's the same when you do a multiphase simulation.
February 2, 2013, 01:46 |
#8 | |
SSL
Rep Power: 14 |
February 2, 2013, 06:00 |
#9 |
Rep Power: 14 |
You are right my friend, the problem that i cannot choose between water or sand phase becouse of the DPM not Multiphase Model.
hydrocyclone, mass flow |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Discrete Phase & Mass Flow Rate | MagnusZeus | FLUENT | 0 | December 2, 2011 17:57 |
mass flow rate computation in fluent | Kishore | FLUENT | 5 | June 27, 2007 03:53 |
particle, parcel and mass flow rate balance | flybird | FLUENT | 0 | May 24, 2007 10:44 |
Target mass flow rate | Saturn | FLUENT | 0 | December 10, 2004 04:18 |
