mixed convection in triangular cavity
Like Tree1Likes
  • 1 Post By imipramine
Old   January 21, 2013, 05:33
Question mixed convection in triangular cavity
alireza malihi
imipramine is on a distinguished road
hi, I'm trying to model mixed convection in a lid-driven Isosceles triangular cavity, boundary conditions are :
left inclined wall: sinusoidal temperature profile (min=290K , max=310K)
right inclined wall: constant temperature at 290K
bottom wall: constant temperature at 310K driven by x-direction velocity of
0.1m/s .
dimension of triangle are :
base = 96mm
hight = 24mm
the question is: which solution method (pressure velocity coupling and spatial descritization) is appropriate for this problem . I can't lead this convection problem to convergence.
can you guys write some suggestions for me ?
thanks
ABDO47 likes this.
imipramine is offline   Reply With Quote
Mixed Convection Inflow BC ?? deji OpenFOAM 3 June 6, 2012 18:09
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 13:11
need help - mixed convection in vertical duct vetnav OpenFOAM 0 May 3, 2010 18:40
natural convection in square cavity Dhileep Main CFD Forum 0 January 11, 2009 11:29
Why TGRID recognized triangular faces as mixed? David Yang FLUENT 0 June 20, 2002 06:48
