December 29, 2012, 13:24 |
Error reading *.cas file
Osamah Ali Al-Hashimi
Rep Power: 14 |
Hi, Kindly i have simple question, I'm confused.
if i send you a *.cas file, how can you read it by fluent? is there another way than: read => case => select file? if so why i have these problems in the attached pix? Error Reading.jpg 2nd error.jpg Many thanks Osamah |
December 29, 2012, 14:33 |
Lucky
Rep Power: 66 |
That's the only way to do it.
There seems to be a prob with your case file. Can you double-check in any way to make sure you have a valid case file? |
December 29, 2012, 14:41 |
Rep Power: 14 |
So whats the problem LuckyTran?
January 2, 2013, 05:49 |
Marion
Rep Power: 15 |
Hi Al-Hashimi,
Have you created the .cas file yourself? have you ever read it successfully? There may be a difference in Fluent versions, or an issue with the file name, or a problem when the file was saved. Marion. |
January 2, 2013, 12:58 |
Rep Power: 14 |
I got the soultion from Mr. Saeed Sadeghi (CFD Online Senior Member), i was using an old version of Ansys Fluent than the version the file created in ^_^.
January 3, 2013, 01:44 |
SSL
Rep Power: 14 |
Thanks dear friend
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
1.7.x Environment Variables on Linux 10.04 | rasma | OpenFOAM Installation | 9 | July 30, 2010 04:43 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
