December 12, 2012, 17:36 |
rotation
kris pani
Rep Power: 14 |
I want your advice.. I am trying to simulate heat transfer in a natural convection problem. My cylinder can is on a rotating disc.. I don't get the results I want, so I am asking you: Do I have to use the Frame Motion option from Cell Zone Conditions in order to put the rotation speed and the Rotation-axis direction or I have to use the option Moving wall fron Boundary Conditions. Maybe both of them? Thank you.. K.P |
December 13, 2012, 10:50 |
Rick
Rep Power: 27 |
you can use moving wall only if you have a surface of revolution (a cylinder is a surface of revolution); you can't use moving wall for the other cases (ex: rushton impeller, which is not a surface of revolution).
Daniele |
December 13, 2012, 12:14 |
kris pani
Rep Power: 14 |
Thank you Daniele !
K.P |
December 14, 2012, 08:05 |
rotation
ali m
Rep Power: 14 |
I am modeling an air turbine in millimeter dimension. and have a problem with these rotation setting!
what should i do? should i set a rotation velocity in cell zone condition for that region(the zone that is rotating)?or in wall rotation in boundary condition? or both of them? please answer me!! Thank u |
December 14, 2012, 08:18 |
Rick
Rep Power: 27 |
Set an absolute rotational velocity to cell zone adiacent to your rotating turbine, then set the walls inside this cell zone to rotate with 0 relative velocity.
December 15, 2012, 03:34 |
hey
ali m
Rep Power: 14 |
yeah
i think you are true but, how do i know (for design), how much of the cell zone, should be in rotating zone?maybe just near the turbine?or a bit far or ...? how much? tanx |
December 15, 2012, 10:29 |
#7 | |
Rick
Rep Power: 27 |
Daniele |
natural convection, rotation |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 07:21 |
Rotation of Can | chhanwal | FLUENT | 3 | March 19, 2011 03:23 |
Problem with patch rotation using pointDisplacement | cwang5 | OpenFOAM Running, Solving & CFD | 3 | July 26, 2010 10:54 |
How to set domain translation and rotation in CFX | ricardo.halfeld | CFX | 7 | September 8, 2009 19:22 |
Axis of rotation for centrifugal compressor | Mattia | FLUENT | 4 | October 22, 2007 12:05 |
