October 27, 2012, 14:53 |
Heat Generation Rate
sagila
Rep Power: 14 |
Dear All,
When I define “Heat Generation Rate (W/m3)” in boundary condition type of wall, and I have fluid cells in one side of the wall, is the defined “Heat Generation Rate” considered for one side of the wall (that I define fluid cells) or for both sides of it? Thanks. |
October 28, 2012, 11:55 |
sagila
Rep Power: 14 |
Dear All,
I would appreciate if anyone could help me. Thank you. |
October 29, 2012, 14:13 |
#3 | |
misagh
Rep Power: 14 |
heat generation doesn't happen in a surface it do happens in a volume as it is obvious from its dimenion:w/M^3 consider Q(DOT)=10 WATT that accurs in a tube with Di=10 cm , Do=20cm ,L=1m here heat generation rate equals:10/v v=pi/4 (Do^2 - Di^2)*L so as mentioned before it happens in the mantle of tube and both sides of tube(inside which is in contact with fluid and the outside of tube)allow the heat flux to pass. good luck |
January 27, 2020, 05:16 |
Benni
Rep Power: 6 |
hi misagh,
But what if I have a contact between two bodies and friction as a result (eg brake disc and pad). Then the heat is generated on the interface, not in the body. How can I solve that? Kind regards |
Total heat transf. rate vs Total surface heat flux | Renato Sousa | FLUENT | 1 | April 14, 2020 03:27 |
temperature dependent internal heat generation | dbrodrigues | ANSYS | 0 | March 31, 2012 01:16 |
Heat transfer rate calculation | Lotta_questions | CFX | 3 | February 11, 2010 18:35 |
HOW TO GIVE BODY HEAT GENERATION TERM | NITUL KALITA | FLUENT | 3 | December 18, 2008 11:23 |
heat generation rate w/m3 in 2D | Laszlo | FLUENT | 1 | May 6, 2004 11:58 |
