install fluent on centos
Like Tree1Likes
  • 1 Post By LuckyTran
Old   October 25, 2012, 13:21
Default install fluent on centos
vahid
vahidss is on a distinguished road
hi everybody
I have installed fluent on centos6-64bit and i receive this error:
can't exec /home/vahidss/Program/Fluent.Inc/license/lnamd64/fluentlm-helper91: No such file or directory
No error handler available
Error: Cortex received a fatal signal (SEGMENTATION VIOLATION).
Error Object: ()
Error: eval: unassigned variable
Error Object: rp-3d?
Can anybody help me please?
vahidss is offline   Reply With Quote
Old   October 27, 2012, 10:32
Stuart Buckingham
stuart23 will become famous soon enoughstuart23 will become famous soon enough
Ummmm, what version of Fluent are you trying to install??? Fluent has been part of Ansys for a few releases (12 onwards maybe?) now, so it shouldn't be coming up as ../Fluent.Inc/... unless you are installing a very old (6.3?).
Try installing the latest version, you should be able to download it from the Ansys website. I have Fluent 13.0 and 14.0 all working on CentOS 6.2
Stu
stuart23 is offline   Reply With Quote
Old   October 28, 2012, 15:36
vahid
yes I am using Fluent 6.3
But I think it should work on Centos.
I think the problem is that I have some missed libraries.
Old   November 7, 2012, 19:04
Qi Guan
entropies is on a distinguished road
Have you successfully install fluent or ANSYS 14.0? I met a problem kind like that too.
entropies is offline   Reply With Quote
Old   November 7, 2012, 19:06
Qi Guan
My problem looks like this:
line 2863: 9468 Segmentation fault $EXE_CMD $CX_FLAGS $FL_FLAGS
The fluent process could not be started.
Old   November 7, 2012, 19:27
Qi Guan
I solved my problem. It has sth. to do with the DNS setup.
Cheers!
Old   January 21, 2013, 01:43
juzer_700 is on a distinguished road
Hi, I have installed Ansys 14.0 on Centos. I am getting the following error:
Segmentation fault (core dumped) $EXE_CMD $CX_FLAGS $FL_FLAGS
/usr/ansys_inc/v140/fluent/fluent14.0.0/bin/fluent -r14.0.0 3d -alnamd64 -path/usr/ansys_inc/v140/fluent -cx iclabserver:55347:45115
Please help hpw to resolve this error. Any help will be appreciated.
Thanks
juzer_700 is offline   Reply With Quote
Old   January 21, 2013, 05:03
Cheers!
Hi, can you help me solving my problem. Please it's urgent.
Old   March 26, 2013, 15:33
Wallace Green
wallace is on a distinguished road
Cheers!
I'm having the same problem. I'm running Fluent in a VirtualBox Scientific Linux. When I've direct access to the license server everything works fine, but when I connect by VPN, I get an error like yours. I think it's a networking issue with VirtualBox but you've figured it out, so please tell us how you did it!!!
wallace is offline   Reply With Quote
Old   March 26, 2013, 16:26
Qi Guan
Sorry that reply you so late. I haven't check this email account for a long time.
You should check your hostname setup in /etc/hostname, make sure that it's the same with the one in your terminal. I found it is the case for my problem.
Old   March 26, 2013, 16:31
Qi Guan
Hi, first of all, I never tried to use VirtualBox.
Second, can you do SSH to the server machine and open FLUENT with the terminal?
Old   March 28, 2013, 13:45
Wallace Green
Thanks for your reply. The problem appears to have been solved, but I'm not sure why. I edited a line in /etc/hosts on the guest machine and things started working fine. But then I commented out that line again and things have still been working fine since. I can't actually seem to reproduce the error any more. I guess it's a OS X / Virtualbox / Cisco AnyConnect / Scientific Linux peculiarity.
Old   April 5, 2015, 06:32
justgoon
yilufeihua is on a distinguished road
Hi.
I have installed fluent6.3 on centos 6.5 -64bit and i receive this error.
I want to know whether you had solved your problem.
Could you help me, please?
yilufeihua is offline   Reply With Quote
Old   April 6, 2015, 06:25
Dering Lee
TurbineLee is on a distinguished road
Originally Posted by yilufeihua View Post
Hi.
You might need to modify your file-- /etc/hosts.
Change the hostname in the file to the real hostname of your computer.
Good luck!
TurbineLee is offline   Reply With Quote
Old   April 7, 2015, 00:13
justgoon
Good luck!
Yes, I add my hostname to the file (/etc/hosts) , then ,reboot. but whitout any effect.
My question is the same as vihadss‘s:
Error Object: ()
Old   April 26, 2016, 06:14
Mariem
Reyouma is on a distinguished road
Hi everyone, I am a new user of Ansys, when I run Fluent I got the following message, does anyone have an idea how to solve this problem? Thanks in advance.
Error Object: rp-3d?[/QUOTE]
Reyouma is offline   Reply With Quote
Old   April 27, 2016, 21:31
Lucky
[/QUOTE]
This thread is specific to centos. Is your problem in any way related to centos?
When you launch Fluent you must specify the environment and whether it is 2D or 3D. In your case, that variable has not been assigned.
i.e. you usually start fluent with:
fluent 2d ...
fluent 3d ...
fluent 2ddp ...
fluent 3ddp ...
Reyouma likes this.
Old   September 3, 2018, 05:08
Default Fix for Ubuntu 18.04.1 LTS
  #18
Lukas Fischer
lukasf is on a distinguished road
hi everybody
Error Object: ()
Maybe this helps:
mv /opt/ansys_inc/v182/fluent/fluent18.2.0/lnamd64/syslib/libstdc++.so.6 /opt/ansys_inc/v182/fluent/fluent18.2.0/lnamd64/syslib/libstdc++.so.6_old
cp /usr/lib/x86_64-linux-gnu/libstdc++.so.6 /opt/ansys_inc/v182/fluent/fluent18.2.0/lnamd64/syslib/.
You have to adjust the path to your fluent installation.
lukasf is offline   Reply With Quote
centos, fluent
heat transfer with RANS wall function, over a flat plate (validation with fluent) bruce OpenFOAM Running, Solving & CFD 6 January 20, 2017 07:22
How to install Fluent on Red Hat Sale FLUENT 8 February 24, 2011 17:23
Launching Fluent: Segmentation fault gravis FLUENT 3 October 23, 2010 10:41
Install Fluent in Linux L3munoz FLUENT 0 July 21, 2009 15:55
Fluent connection with simulink by TCP/IP Tanktruck Fluent UDF and Scheme Programming 1 June 28, 2009 13:56
